Hello guys
Once again, I am here to request some help from you:
I have a pro skier of 2000, with 5.7 motor from GM.
Saturday, the day was perfect to do some surfing. Unfortunatelly, the boat didn't start...
I spend 3 hours to check everything with my little mecanical knowledge.
From what I saw, the motor shoke but do not start. Battery is new (2 weeks old).
I disconnected all the connectors to clean them, checked all fuses.
The boat start once when I put some gasoline directly on the carburator. Then, it keep working and the injectors was working. I stopped it after few minutes and retried to start again and same issue. From that time, even if I put gazoline on it, it just work few seconds.
For information, this season, I only spend 2 days on the lake... The gazoline on it stay from last year (I keep the tank full of gazoline during winter to avoid condensation). Do you think the gazoline is bad? The one I was putting on it manually was from my jericane with fresh one.
Thanks for your support.
Regards
Patrice
Regards
Patrice
