The decals from a new to me "ghost" all white X2 were removed last night and under them was a yellowish stain that required sanding. The more it was wet sanded, the more it blended in to the weathered hull. It was definitely discoloration under the decal, not vice versa. Anyone ever experienced this?
Decal removal discoloration with a twist
I ran into the same issue with registration numbers on the top of my new to me X5. The only thing that dulled the ghosting / discoloration was using my DeWalt rotary with a fairly aggressive pad. I used a marine oxidization compound remover (Meguiars). Took the discoloration out about 90%, but it left an orangeish "stain" on the gel.
A little sun faded the ghosting, but I can still see there the original registration numbers were originally located. I hope there is a solution to the issue, I would be interested in all replies.
Originally posted by tjrowbot View PostI ran into the same issue with registration numbers on the top of my new to me X5. The only thing that dulled the ghosting / discoloration was using my DeWalt rotary with a fairly aggressive pad. I used a marine oxidization compound remover (Meguiars). Took the discoloration out about 90%, but it left an orangeish "stain" on the gel.
Exactly. There is a solution. Takes an aggressive cut. Just verified in sunlight that mine is gone. 400/600/800/1000/1200 sandpaper followed by 3M Super Duty followed by Finesse It. Took about 1.5 hours. Now on to the other side.
Still very curious as to what causes this.
Originally posted by DavidF View PostThis is my worry with removing the bullseye decals on my 08 x30. I want to update the look a bit but afraid of the leftovers. I guess my dealer could do it for a price... at $135/hour...Prior boats - (3) X14's, (3) Prostars, and a Tristar.
I had exactly the same problem on my '00 Xstar. I think I even put a post up about it. The area under the decals were also raised slightly, which was a blessing in disguise as it made flatting the area off and cutting the raised/stained area a breeze.
