Figured I'd start a thread for those interested in changing from the stock prop size on the XStar.
I didn't spend as much time, as I should have, collecting data on my swap. I have a few data points though, and I am happy with the switch.
Stock prop with the 6.2 was an 18x16 OJ. I switched to a 18x17.5 (#3289) ACME prop. This is what I observed-
- Top speed was 35 on the stock prop, it is 41 on the #3289.
- Surf rpm was 3350 on the stock prop at 11.0. Its 3100rpm on the #3289
- No problem getting to wakeboard speed with stock ballast full plus 1100 bag on center floor. I'd say (educated guess), that it would handle stock+ 2-3k of ballast and people, before you'd need to drop back down in prop pitch. Who knows though, autolaunch is a wonderful feature, and I was only using single tab....
- I didn't get any GPH data, but I can tell you that a couple hundred rpm drop at surf speeds will typically reduce consumption dramatically. I did a long term measurement on my G, on a similar prop change. The new prop dropped surf rpm from 3300 down to 3000, and that dropped fuel consumption from 9gph down to 6.5gph (both measured over an entire season and 150ish hours each).
In past experience, I had seen cleaner surf waves on several different boats with an ACME prop (no idea why). I saw no change on this boat at all. I also surfed both sides before and after the switch. No change, except that the boat is a little quieter on the ACME because of the increased pitch, and lower RPM.
I'd have no issue with trying an equivalent prop from OJ on this boat...... And Eric is awesome to work with, if any of you want to try a different prop, and haven't worked with him in the past.
I should have GPH data on this new prop before too long. This time of year is a good time to get an accurate reading. The boat only goes out to tow this time of year.
