A little info for those that might be curious. I have a 1993 prostar 205 carbed 351 ho 285 HP with 1:1. Couple years ago I bought a deal in two props from a member here. 13x13 4 blade cast and 13x11 3 blade CNC. My boat had the 13x13 3 blade original cast on it. All three props excellent shape, no dings, nicks, or flaws of any kind.
First I tried the four blade, noticeable hole shot improvement with top speed about the same as the original three blade. If anything, 1 mph slower. 41-42 mph. Kinda hard to explain, but to me it's the smoothest pull of the three props. Almost feels electric.
Lastly I tried the 13x11 CNC three blade. Best hole shot, but only by a little over the four blade. Best top end, 44-45 mph, but of course runs a little high in the rpms. Maybe around 4700-4800. This is the prop I left on my boat and currently use. I also had a powerslot prior to this boat and the 13x11 is the closest thing I have to make it feel like a powerslot. I also seem to have a touch better fuel economy and the engine seems to be in less strain than with any other prop I've tried.
Sent from my XT1030 using Tapatalk
1994 Prostar 205 prop replacement
Installed the ACME 543 tonight on my 94 Prostar 205. Wow! I have been missing a lot. It pulls so much better and smoother at speed. Hole shot is significantly better and getting easy 38 mph. Very impressed with the performance. I was going to keep my old one as a spare and boy I hope it never has to get used unless it’s an anchor.
Leave a comment:
Originally posted by jayR View PostMy take on this is more hole shot.... more cow bell too ! So I went with a 13x11.5... if you have an older standard (non HO) 351 engine or are at elevation I think you will benefit. I am not a bare footer, nor do I need extract every mph out of the top end. bare footers might feel different.Glad you found what works for you though..
Leave a comment:
Leave a comment:
dfski - Give me a call when you can and we can discuss your options.
Leave a comment:
Originally posted by dfski View PostEric (or others) I’ve contemplated trying a CNC prop for a while but I’m pleased with the performance of my 13 X 13 conventional 4 blade. What benefit would I really see on a 92 PS 205, 351HO, if I went to one of these other choices?
What factors should I consider in choosing between the 13 X 11.5 LC 1" 3-blade #310 or 13 X 12 LC 1" 3-blade #314
PS I want to add that both I and my son (93 PS 190, 351HO, Power Slot) have been extremely pleased with the advice/service from OJ in the past and would highly recommend them. Because of their support, I have a hard time considering other options
Thanks
Leave a comment:
Originally posted by EJ OJPROP View PostPicking mic back up....Would suggest trying our 13 X 11.5 LC 1" 3-blade #310 or 13 X 12 LC 1" 3-blade #314..… You're welcome to try them both to see which fits your needs best. We also offer a free in house repair of your current prop when you purchase a new prop.
Thanks
Leave a comment:
Oops! (as we hit a rock) What do we do now captain?
Originally posted by EJ OJPROP View PostUnderstand beyond repair. Also offer an additional discount when the prop is beyond repair. Feel free to call if you have any questions.
Leave a comment:
Leave a comment:
Originally posted by d2jp View PostIf I had some spare change, I would like to compare the OJ 13x11.5" to my 541. I will agree with the review that the 541 really growls when you cut the throttle at speed. Dang Teamtalk, makes you aware of problems you didn't know you had AND there could be a better prop out there
hahaha How many props would you like today sir? As we here like to say: Speed costs money. How fast would you like to go?
Leave a comment:
A good unscientific review of prop options. Not the exact same boat but good feedback none-the-less with a nod to the OJ options:
http://www.mastercraft.com/teamtalk/...ad.php?t=31670
Leave a comment:
Leave a comment:
Leave a comment:
I wen't to a 541 Acme as well on a '98 Pro. 190. Great out of the hole and top end is at 44 on both Speedos. (Hand held GPS aswell) Acme told me to try that prop and if I don't like it, send it back and try another one. I talked with Jim and told him my set up. He's the guy that suggested the 541. I'm not knocking the OJ, just telling of my dealings with Acme. If you have the option to try, I would certainly use it. BTW...a junk prop is better than no prop. They are costly, I sure would no throw it into the dumpster.
Leave a comment:
Leave a comment:
