I bought the plastic set of fuel line tools that fit 5 different lines sizes. It won’t slide under that metal locking thing in top of the line. Does something have to be done with that “lock” first? It’s not really a lock but it’s some piece of metal that come from on top of the line and kind of holds the line in place maybe. If you’ve done this before you know what I’m talking about Thanks!
I cannot get my fuel line off!
Ok, thanks. How do I remove it exactly? I assume you don’t mean actually REMOVE It, but somehow disengage the clip? Should I use a little screwdriver to pry it up? Do I push the tube a little forward first? Sorry for the dumbass questions.08 X30 - deader than dead...and crispy.
Originally posted by DavidF View PostOk, thanks. How do I remove it exactly? I assume you don’t mean actually REMOVE It, but somehow disengage the clip? Should I use a little screwdriver to pry it up? Do I push the tube a little forward first? Sorry for the dumbass questions.
Post a photo.
Originally posted by DavidF View PostI’ll see if I can get one in a bit. And do I need the disconnect both batteries first? Hard to get to the second one.
The clip has prongs that slide inside the line and then two clips that are under the orange hose. Once you get the clips off the side under the hose, slide it forward and you’ll be set.Aric
LONE STAR MASTERBASH 2022
Register Here
2019 XT22 - Ear Bleeder
2022 Sea Hunt BX22 CC
For Sale:
2020 Crest 240 SLC Tri Toon
