2019 X22
  • #46
    Originally posted by lashburn1 View Post
    Yeah...I dont think the problem is the "year" or "Ca"n you use them, It is "shoud you" use them? They will activate on all years/...
    At cruise speed the GEN 2 Surf tabs are like Water Scoops.
    I would like to know if the Actuators are engineered for that speed and Purpose. ?
    That's what Im thinking, using the tabs at higher speed would rip them off IMO. Look at the fins on the bottom of the GEN2 tab.
    • #47
      Originally posted by Mastercraftdave View Post
      Are you sure this applies to all boats?
      If they still have the fins on the bottom of the GEN2 X23 tabs, I'm not sure how you can use these while underway.
      I do use all three tabs for auto launch, but they retract at 16 mph.
      Originally posted by jgraham37128 View Post
      I have a 2016 X23 and use the tabs to level while underway all the time. No limit on speed when you manually select them.
      Originally posted by moosehead View Post
      ^+1 to Larry's comments. Using trim tabs/actuators regularly on a big heavy boat to potentially solve basic cruising manners is very different than say trimming up a sterndrive to hit maximum top speed.
      From Mastercraft's website:
      "Surf tabs can also be used as trim tabs to help level the boat that has an unbalanced load on port or starboard or when a strong wind is present...
      On the X2, X10, X30, X46, and XSTAR models, GEN2 WSDs are limited to seventy- five percent (75%) maximum extension when the boat speed exceeds twenty miles per hour (20 mph) or thirty-two kilometers per hour (32 km/h).
      On the X20 and X23 models, GEN2 WSDs are limited to seventy- five percent (75%) maximum extension when the boat speed exceeds twenty five miles per hour (25 mph) or forty kilometers per hour (40 km/h)."
      Source: http://www.mastercraft.com/knowledge...n2-Surf-System
      There are bigger and heavier boats out there running larger tabs using the same actuators that MC uses for the sole purpose of leveling the boat at cruising speeds.
      (Previous- '08 X2 w/MCX)
      www.chesnuttech.com
      • #48
        Well, this thread took a turn
        Aric
        LONE STAR MASTERBASH 2022
        Register Here
        2019 XT22 - Ear Bleeder
        2022 Sea Hunt BX22 CC
        For Sale:
        2020 Crest 240 SLC Tri Toon
        • #49
          I don't disagree, however, most trim tabs have a flat running surface, GEN2 tabs aren't a flat surface.
          I can't see myself putting the port tab down with those fins on the bottom. That just doesn't seem like a very smart move IMO. I guess I could use the starboard tab for balancing, but if I used the port tab it would make the boat pull hard to one side with those fins on the bottom.
          • #50
            Look at the fins with the tab 20% down and tell me if you still feel that way. Its hard to picture but the tab is at an angle and goes down on that axis. They would not be in the water at a huge crazy angle.
            2020 Table Rock Mastercraft Reunion Poker Run Champion
            I lead the fight to ban the swimsuit thread, help me bring it back: https://teamtalk.mastercraft.com/sho...58#post1494758
            "LDA never saw a thread he couldn't run off the rails"
            • #51
              I have looked at it personally when we first got the boat as I thought we could use these to level the boat, but the fins on the bottom of the tabs are about 1 1/2" tall. The 2015 tabs don't retract as much as the 2017-2018 models.
              Any movement on the tab, the fins will be in the water first regardless of the angle, and when the port tab is in the water, you have to counter steer a lot and its really not safe. The whole purpose of the fins on the bottom of the port GEN2 is to help divert water for the delayed convergence.
              If both of the tabs were flat on the bottom I would say this would work, but after 4 years and 300 hrs, I feel confident saying these tabs aren't meant to be used for leveling the boat.
              • #52
                Oil change time.
                • #53
                  These topics are on point for the replacement to the X23, or for its big brothers.
                  Neither of our crossovers have porpoising, both require crew adjustments to dial but that is perfectly acceptable and effective.
                  IMO, the X22, X24, and XStar at well closer to $200k+ than $100K, should have out of the box stock cruising, wake and surf nailed down period. In my time on the XStar that is indeed the case.
                  MCOCD interested in knowing how MC did so relative to the X23. I could care less that Aric still uses the wrong oil spec.
                  • #54
                    Hey guys, did you see MC released a new boat, the 2019 X22??
                    • #55
                      Ha ha ha! Thread jacks...gotta love em
                      Former: 2007 X15
                      • #56
                        Q: "Hey guys - guess how we're going to decide who rides first?"
                        A: "Your parents FICO Score"
                        • #57
                          From Factory today- yes , GEN2 Tabs can be used to level ride at Cruising speeds.
                          I was mistaken.
                          sigpic
                          2014 Chap 264 Sunesta
                          2019 XT25 GEN2 5500
                          2015 X20 SS GEN2 6.0
                          2016 G21 Coastal 5.3
                          2014 X46 GEN2 7.4
                          2014 X30 GEN2 5.7
                          2006 VRS200 SS 5.7
                          2013 X30 GEN2 6.2
                          2013 Yamaha 242LS
                          • #58
                            This seems to Jive with triple tab auto launch.
                            • #59
                              Bringing this thread back on topic, episode 3 is up on Youtube:
                              Enjoy the videos and music you love, upload original content, and share it all with friends, family, and the world on YouTube.
                              www.chesnuttech.com
                              • #60
                                I made the video!
