Thought about the same thing but that big caddy still has to get in and out of the truck.
Large Gas Can/Caddy Recommendations
20 gal is approx 140 lbs right? Do you have smooth level path from your tank to dock? That’s a decent weight move around if your back is bad. Although not having to lift in / out of truck would make it interesting.
4.5 gal in the 5 gal can isn’t too bad / heavy.
I’d see how much gas you actually burn first, since you have ski boat vs wake barge.
Originally posted by lakedrum03 View PostThought about the same thing but that big caddy still has to get in and out of the truck.
I haven't used it yet because I picked it up late last season.
I can post some pics if anyone is interested.
Originally posted by Wheelin98TJ View PostI have a cart that holds the caddy. The cart loads into a hitch receiver and has a built in ramp.
Yes please post pics when you can. Thanks
This is the best setup I've found.
https://flofast.com/product/flo-fast...gallon-system/
Loading and unloading 15 gallons is about 95lbs, but since you are just going right to the cart it's not that bad. My seven year old daughter can empty the can with the hand pump in about 6 minutes. Faster and beats wrestling with race cans of you are needing more than 10 gallons.
Originally posted by Thrall View PostBurner, lol, people like that are enough to p!ss a guy off. I have several of them in my life (mostly state inspectors and the d bags at the Brown Bear car wash that won't let me take my truck with a diesel slip tank through the car wash anymore).
What would that ole bat have done if you told her you were going to shove the fuel nozzle up her ____ if she didn't back off?
Have you arrested for filling your gas jug at Costco??
Some people....
Wonder what day of the week it was!!'06 X2 MCX
Originally posted by JohnnyB View Post2 - 5gal VP Racing jugs and flexible pour spouts.
Carrying them down to the dock and into/out of the truck helps build a strong slalom grip.
Sent from my SM-G960U1 using Tapatalk
whatever you go with stay away from the flow n'go jugs with wheels. My sister had one of those and it was the worst thing ever. never stopped leaking, you always had to have it higher than the tank because gravity fed. it just sucked.
2004 Prostar 197 TT LQ9(sold)
2008 40th Anniversary Prostar 197 LY6
Originally posted by Rocketboy View PostI have a fuel barrel in the back yard. Today I carry the cans around. I was thinking of a 25 gallon caddy so I could just fill and wheel onto the dock and fill the boat. I have a bad back and holding those cans sucks for me.
The one with the hand pump- how long to pump 20 gallons?
Originally posted by h_2_o View Postthis times about 100, but for me i go with the generic ones if you have a rural king near by theirs are basically the same but only $20 each.
Sent from my SM-G960U1 using TapatalkEveryone Dies, but not everyone lives
2004 Prostar 197, ACME 843
Originally posted by MIskiboat View Post20 gal is approx 140 lbs right? Do you have smooth level path from your tank to dock? That’s a decent weight move around if your back is bad. Although not having to lift in / out of truck would make it interesting.
Thanks for the input.
I use a Flo-n-Go, which holds 14 gallons and is on wheels. I took the worthless handle pump off, and use a siphon shaker and it works great. I also have six 5 gallon jugs that I also use for the boat and the jet-ski's.
First thing I do when I get to the cabin is load up the above cans, and run to the gas station and fill up....this is usually enough to last all weekend.
If money isn't a concern -- Gas Dingo is the answer...
http://gasdingo.comLast edited by Eckie; 02-24-2021, 12:31 PM.
