I rebuilt my 4160. Float question. Primary float was good to go. Level. Secondary float inverted bowl was a little higher than level from the floor of bowl. Directions that came with rebuild kit illustrates level. What should secondary float be? Boat runs fine. Should I leave it as I found it?
4160 Holley
Tried to respond to your PM. I don't know any detailed info about carbs. Always ran mine at recommended settings at relatively low altitude with great success. Good luck!Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Holley spec is to have the float level. In my experience, some carbs don’t like this so I set mine slightly low (slightly high when inverted).
Sent from my iPhone using TapatalkCUSTOM WHEEL & TIRE PACKAGES
sigpic
Email - [email protected]
