2000 Maristar with $$$ in parts and months of time
  • 2000 Maristar with $$$ in parts and months of time
    Figured I would post what I have done to this as it might give people ideas of what can be done.
    Now I have a GSA system Black Anodized with Platform Brackets sitting in the garage as I cannot see how it's going to work due to transom design. So almost there with a boat that can surf.
    Now about to pull the trigger on a 19 Star...
    1. Trailer Wheel Bracket - To allow wheels to hit before bottom of trailer on steep inclines.
    The white lights are Backup Lights
    Samson Tower Install
    Samson is amazing to work with, super high quality stuff, The tower was measure, measure, had to be super MCOCD to do it right.
      Ballast Install
      All Wavemakers, MC Relay Box(the right way), measure, drill a bunch of holes on he bottom/sides. Drain/Vent out of the side, Fill in the bottom, 3 pumps, one for KGB, 1 for each rear locker 720. Divider supports from wave makers
        Replace Medallion Gauges
        Replace Medallion MDC-1600 and Gauges with Faria, Thanks to the thread on TeamTalk
          Stereo Install
          Add a 3rd Battery, All new Wire. JL AMP's, Now has a Blower Motor across the AMP's to keep them cooler.
            Can you post pictures of the GSA system and the problem with the transom? I've been thinking about trying this- the suction cup wake device works well, but I'm intrigued with tabs. Can you maybe explain what the issue is? Tabs too wide- not enough mounting surface to attach? Not enough space to mount the actuator?
            G
              You have some serious jack tied up into this project.
              The workmanship and quality of the installation look great. Nice work!
                Yes Sir, If I counted my time, pretty insane $.
                Boat to do list(Complete):
                Alternator not charging- put 50A back on - done
                Center locker ballast hose too long-done
                Left most vent leaking water-done
                Speakers whining ordered new connectors 4-19-done
                Tower Speakers rotating -file a flat-done
                Speed control not holding speed-done
                Front Ballast Polarity Reversed=done
                Neoprene sleeve for wakeboard bungee - ordered 4-19-done
                Latch strap needs securing-done
                Cap off rear engine steam vent-done
                Replace hose between flush pro and thru hull-done
                Check strainer seal-done
                Rotate manifold drain valves-done
                Replace Switch Covers-done
                Blower-done
                Pump-done
                NAV-done
                Courtesy-done
                Underwater Light-done
                Rear check valves for fill not working-Ordered new style check valve from wavemakers-done
                Misfire at high rpm
                Spark plug wire resistance- 3=6k, 1=4747(bad), 5=6.9k, 7=8.9k,
                Right bank spark plugs white=lean
                Left bank =lean
                Replace spark plug wires-done
                Replace MAF-done
                5/19/2015
                Fasten deck platform bracket-done
                Adjust throttle cable-done
                Install trailer lights-done
                Replace ft bag fitting-done
                Not shifting into Reverse - Adjusted
                Windshield Jammed - Fixed
                Ski Locker - Sand top so smooth
                Whine speakers
                Stock Injector:
                RP(Rochester) Injector W 83(each one different)
                Part # 17121068
                12.1 Ohms 256cc at 3 bar
                24 lb
                Replace Injectors Bosch - done
                  Attempt at Wedge
                  So I wanted to build something that fit the contour of the hull, secured with Velcro, So success on that front, this is built out of a Foam Block, 8 layers of 8oz glass, then gelcoat, sanded.
                  Wave result, not great.
                    G
                    The GSA System is sitting in my garage, still sealed in the box. I used the templates off wave makers to see how I was going to get it to fit. I also have a roll of Seadeck brushed Tan I have sitting there.
                      Replace MAF-done
                      This boat doesn't have a MAF sensor, it has a MAP sensor unless it was modified. If it does have a MAF sensor, it should also have an IAT (Intake Air Temperature) sensor.
