1999 MasterCraft Prostar 205
Still trying to slalom a few times per year but nothing spectacular (about 32 mph, a few cuts across what I hope to be the smallest wake possible).
Also starting to surf more with an 800lb bag (probably only 80% full) in the back and a 400lb bag on the side. Use a wake shaper (Mission Delta).
When living in Colorado, was recommended to get a prop for elevation (8500'), an ACME 1609
(13x11.5", 0.60 cup 3 blade). Now living in TN and this was running > 5000 rpm at full throttle. This prop is now damaged
Original prop from MI was OJ 402 (12.5x12", .090 cup 4 blade).
Any recommendation on what to use (i.e. should I replace the 3 blade)? I don't think I need top speed with full ballast as I can empty bags if needing to go fast across lake.
