Hello all,
This is such a great page of knowledge on the Prostar thank you for sharing. I hope I get my 205 running for the 4th or I am a dad who will be in the dog house.
I have had my 1993 out a few times this year the first time it started cold but after turning over ran great. Second time out it started ok and pulled a wakeboarder and kids skiing. The engine was purring like a kitten. Later that evening I reluctantly pulled the kids on the tube for about 30 minutes and parked it. The next day she had some trouble turning over but was able to get it running. Out on the water I could not put it in neutral with out it shutting down so I kept it with a the rpm at 1000 with the throttle engaged. I was thinking it may need a new wix water separator filter so I was going to replace it and put some additive to the gas to see if I could get it to idle higher. I mistakenly took off the oil sensor and not the wix water separator filter. I put the oil sensor back on and replaced the wix filter. I went to start it up and was able to get it going for about 5 seconds before it stalled but this time it would turn over but not fire up.
I am at a loss I think it may have something to do with the carb. As you can tell I do not have a strong background working with engines but I am trying to learn. All of the boat mechanics in my area are three weeks out before they would even be able to look at it. I checked and double checked the lanyard safety clip but I don’t think that is the issue because I was able to get it to turn over for a few seconds.
Thank you for any advice you have
