Thanks to Moosehead I am the proud owner of a very well kept 2015 X30 - you've seen photos of his X30 over the past few years. I think this might just be the best looking X30 to ever roll off the assembly line in Vonore, TN! I can't say enough about Moose and his and kindness. He was willing to make the trip from CO to northern ID in May amid this crazy Covid outbreak to meet my wife and me when we drove up from UT for the lake test.
I have taken what was an extremely nice boat and made it my own by applying my MCOCD to correct some things that bothered me - mostly what I viewed as design flaws and personal preferences really.
Below is a list of the major projects:
1. Replaced all OEM rubber Aqua Trac pieces with Gatorstep (props to Mason & crew).
2. Replaced OEM heater with Heatercraft 300 Elite (2x the BTU's, replaced cup holder vents with actual cup holders and added a 2nd Hot Tube in the walkway to the bow).
3. Relocated batteries to rear, port coffin storage - secured to a custom HDPE/carpeted shelf.
4. Relocated pylon storage to area beneath the trash can.
5. Relocated driver's seat heater switch from location at side of driver's seat to switch panel at helm (including patching fiberglass and gelcoat where switch was previously located).
6. Replaced fiberglass swim deck with teak deck from Teak World (props to Tommy & crew).
7. Replaced leaking propeller shaft seal and log (props to Corey @ UWS).
8. Cleaned hazy film off inside of gauge glass - tachometer and 3-in-1 gauge (hazy film made reading the gauges at night very difficult).
9. Installed LED rub rail docking lights (thanks Moose) and OEM "Dock Lights" switch at helm switch panel.
10. Secured folding swim deck brackets to eliminate deck movement.
11. Added a 4th "stop" position to ZFT4 port side rack to allow my Ski Ski rack to lock into a position that allows the use of the over-the-tower cover and also prevents the rack from rubbing the vinyl upholstery (this will likely only make sense to the few of you who have installed a Comptech hydrofoil rack and tow with the ZFT4 collapsed).
12. Modified both ZFT4 racks to eliminate the loose, wobble of the racks (This was one of the first things I noticed when I test drove the boat. My '06 racks could be secured in place with the use of a threaded knob to lock them firmly in place but these ZFT4 racks have no mechanism to tighten - they simply rely on the spring loaded, tapered pin to hold their position).
13. Will be adding a Heatercraft hot water shower when it arrives later this week.
14. Swapped the TDE trailer brake actuator for a UFP XR-84.
If anyone is interested in seeing and/or tackling any of these projects I'm happy to provide more detail and photos.
Thanks again Moose! We are loving the boat and she'll be well taken care of.
