I had the dual screens on my 2018 XT22, decided to go with the 7" screen this time. For the most part, agree with Tookeymonster. Those added features of the dual screen are just not that compelling.
I will say, there are some things about the 7" screen that do drive me nuts. With the dual screen, the surf screen has touch buttons for Left & Right, Steep & Mellow. Made swapping waves pretty quick and easy. The 7" screen only supports left and right. Also, I'm finding the profile selection process to be maddeningly bad. Not sure if it is different than the dual screen, or if it is because I have fastfill. Specific issues:
1. When starting a surf session, does not remember the last surf mode after the ignition is turned off. Always defaults to 'None', and have to go in and select a profile.
2. Compounding matters, the last surf profile shows as 'Active' already, even though it isn't. I have to 'Activate' a different profile first, then come back to the one I want.
3. First activation of a profile during the surf session, it first gives me a warning screen about keeping RPMs under 1500 while filling. I select 'Okay', then it makes me go back and select 'Activate' again, rather than just starting to fill.
As I said, not sure if these are unique to the 7" screen, or fastfill, or combination. But it is the most illogical thing I've ever seen. And as mentioned above, I'd like to be able to modify the standard profiles, as the Left and Right button are tied to those. I thought I remembered being able to modify the standard profiles on the dual screen, but maybe I'm remembering wrong?
