I assume you tried taking the tires off the trailer and lowering it to the ground before trying the truck bed engine crane?
Damper explosion
Originally posted by Huckelfin View PostWould it be fair to think about the root cause of this failure in addition to fixing it? The chosen springs are meant to dampen the vibrations to a certain design case, so why did it blow apart? You didn't mention springs rattling around before the failure & it doesn't seem like it's old enough to just say that years of use caused some things to degrade.. is something else in the driveline providing abnormal stress?
IE: if this is replaced, what are the chances it just blows apart again? Maybe just overthinking it, surfing loaded down causing the problem.
Lower mass is great for faster acceleration/less inertia, but they really need to make these parts stronger.
I have not looked to find the old threads but the 2005 model year did have weak damper plates. Lots of low hour failures back in the first several years. I have an 05 197 with the 6.0 LQ9 and it developed a rattle at around 300 hours. I got nervous as it got worse and changed it around 350 hours. When I pulled mine a couple springs were loose and the plate had a small crack. I do not think it is a skiing vs surf load thing, I think it was just a bad batch of damper plates. I put a heavy duty one in mine from DIM and it has been quiet and smooth since, I now have just over 1600 hours on the boat with no further issues. Take a look at this plate, I know it has served me well.
https://www.skidim.com/prodinfo.asp?number=R1400182005 197 TT #77 LQ9
Originally posted by JimN View PostThe springs may dampen vibrations, but the plate still has to deal with the stresses from hard acceleration that deform it.
Oh I agree that the plate is under a lot of stress but I was mostly just trying to speculate the true failure mode & if it had to do with the damper plate not effectively dampening. It looks like the center completely tore out in this case.
Originally posted by mcmx2 View PostI have not looked to find the old threads but the 2005 model year did have weak damper plates. Lots of low hour failures back in the first several years. I have an 05 197 with the 6.0 LQ9 and it developed a rattle at around 300 hours. I got nervous as it got worse and changed it around 350 hours. When I pulled mine a couple springs were loose and the plate had a small crack. I do not think it is a skiing vs surf load thing, I think it was just a bad batch of damper plates. I put a heavy duty one in mine from DIM and it has been quiet and smooth since, I now have just over 1600 hours on the boat with no further issues. Take a look at this plate, I know it has served me well.
I am going to disagree on the ski/surf load. The harmonic balancer and the dampener plate absorb/even out the pressure of the combustion stroke. Heavy load high gearing not great ur lugging the engine at surf speed. All that pressure being transferred to dampner springs and the trans is pushing back with its own forces. My opinion on hours of reading, i compare it to driving car up hill and trans downshifts, for higher rpms.
Originally posted by kman View PostUpdate: We got the motor out using a lift in the back of my truck method. Very nerve racking, but actually worked pretty well. Just took our time and moved slow. Getting it back in is going to be the bigger challenge.
Originally posted by gwozhog View PostDude your crane made my pulse rate go up. You can rent a gantry lift2005 X45 - L18
Originally posted by 88 PS190 View PostI assume you tried taking the tires off the trailer and lowering it to the ground before trying the truck bed engine crane?2005 X45 - L18
ron tanis did a video on damper plates, I believe he sells them too. here is the link.
https://www.youtube.com/watch?v=fylwfmJgaXY
Originally posted by gwozhog View Postif your surfing it will be sooner than later
I would guess the newer boats are better designed to take the amount of weight people put in them.2002, X30, L-18, Red Metal Flake (the possessed boat)
Originally posted by Huckelfin View PostIt looks like the center completely tore out in this case.
I saw the old part- looked like a way to save money, more than anything.
