I installed my new fuel pump (155215) and also got the new wiring harness (501000). The wiring harness converts the 2 wire (grey and black) into a 4 wire harness (2 black and 2 grey) to run the duel pumps inside the new fuel pump assembly. The connector on one side of the new harness has 2 pins and the other side has 4 pins. The yellow connector on the new fuel pump has the mating 4-pin connector.
My problem is the old yellow connector on the old fuel pump has 3 pins (grey, black and green). The green wire comes from the harness that goes to the fuel gauge meter. Using the new 4 wire harness leaves the green wire with no place to be connected to. Has anyone upgraded their fuel pump and used this new 4 wire harness? If so, what did you do with the green wire?
