Originally posted by Stevensc
View Post
How old is the fuel in the tank? Sitting fo a long time and ending up with bad fuel tells me this could be a fuel quality problem. Your fuel line should have a Shrader valve- you need to test pressure on the water, not on the trailer in order for the test to be valid- it needs to be under load. While you're at it, take a fuel sample by using the purge valve on the gauge to allow gas to flow out of the clear tubing into a clean, clear bottle. Let it sit for awhile and look at it- if you see water or other fine debris, you need to clean out the tank.
I saw mention of the fuel shutoff at the tank- make sure that's open and if it has a long fitting after it, make sure it doesn't have anything blocking it- you would be surprised by the stuff I have seen in fuel tanks.
Are you still accelerating noticeably when this happens, or are you close to top speed? At what RPM is it happening? If it's in the 3500 ±200 RPM area, remove the fuel pump
