Raising the swim deck on 06 X2
  • Raising the swim deck on 06 X2
    Hey guys, does anyone have any experience on raising the swim platform on an 06 ish model X2? The teak appears to be cutting into my surf wave, and I’m curious how hard of an alteration it it is. The transom has a outward V shape where it meets the deck compared to to a subtle ) on a lot of models. Thanks for any input!
    don't know what type of platform you have but after i added GSA to my 07 i raised my platform 3 inches. I bought some 3x2 alum tubing off the internet and had them cut it to the length of the brackets. then drilled thru the tubing to allow me put the screws thru the brackets and reaching the teak. No problems yet and i did this 4 years ago. I did paint it black to match the brackets and actually installed plastic plugs to make it look better.
      GSA or WakeMakers sells 4” platform raisers that’d be perfect if you don’t want to diy. I have them on my 06 X30 with the same V shaped transom as your X2.
      -Tolman
      '22 XT23 "Big Kahuna"
      '06 X30 (Sold)
        Pics please!!!
        OH-IO!
          Raised Platform on 205V
          Not the same boat but....
            ^^ very similar as i did.
              Nicely done! I assume you just marker the holes in the brackets and drilled about 3/8 holes thru the blocks and then used 4" screws to hold the platform???
              OH-IO!
                that is what I did and it is doing great. we can even still remove the platform to clean up at the house.
                  The most improvement I've made to my wave was adding the center trim (attitude adjustment) tab. Cleaned up the wave. I cut down the sides of my teak platform, but until I added the tab the top of the wave was just washed out. Here's a post with a picture comparing my two swim platforms:
                  https://teamtalk.mastercraft.com/sho...1&postcount=63
                  2006 Maristar 200 SS
                    Raised Platform
                    Ditto and Ditto.
                      I raised the platform on our x-14V using teak wedges that I cut. You can see pics and how to in post #185 here (scroll down to the bottom of the page) :
                      https://teamtalk.mastercraft.com/sho...=39449&page=19
                      Its been 6 years now and it is still very solid
                        Teak risers
                        Looks great!
