My 2020 XT22 came with the factory heater option which is a 9" heater unit by Maradyne. It features four, 2" outlets and supposedly puts out about 28,000 BTU. My dual screen dash is wired for high or low fan speed outputs. The fan volume was fine but I was looking for more heat output as we boat in cool waters and sometimes late evenings and the family enjoys the cabin heat.
After researching higher BTU units from both Maradyne and HeaterCraft, I purchased a HeaterCraft 340 Elite Unit directly from HeaterCraft (they had better customer service and answered a lot of questions for me). Essentially, I went from a 9" unit to a 16" unit which is essentially a larger radiator unit. I finally got it installed and tested after it took 60 days for delivery!
The HC unit has 4, 3" outlets so I had to buy some 3" to 2" reducers which I got off Amazon. They are silicon turbo piping reducers (queue Fast & Furious).
I carefully cut off the factory electrical connector from the Maradyne unit and skillfully integrated it into the HC wire harness so everything is plug and play and looks factory. Both fans (Maradyne & HC) are wired for high, medium, and low but the output from the boat is only one hot wire and a ground. The boat only has high and low settings and must control the amperage? through the hot lead telling the fan to be in high or low mode. I wired the HC fan to the "high" setting but both high and low through my screen work.
I've only had the boat out for a 10 minute pre-season shakedown run and there was heat, but I have not done a full family assessment yet but so far, things look good.
First pic is of the factory Maradyne unit.
My factory MasterCraft/Maradyne unit is now for sale.
