Trim tab bracket orientation
  • Trim tab bracket orientation
    Can someone confirm which way the bracket faces on the trim tabs?
    Thanks
    Thanks
    What year and model are you trying compare against?
      Dunno about your NXT but on 2015+ Gen 2’s you want the tab mount to actuator to be shortest distance to the transom so that the tab tucks up under the swim platform when not engaged.
      Sent from my iPhone using Tapatalk Pro
          I have a 2021 NXT20. The bracket on the tab has an offset hole and depending on how the pin is installed the tab can be closer or further away from the platform when retracted. There is also an arrow etched into the bracket and currently the arrow is pointing towards the boat. In this position the tab is further away from the platform when retracted than it would be if I spun the bracket 180. Here's with the bracket installed in both positions, which one is correct?
            After looking at pics online I'm pretty sure I got it backwards, it should look like the bottom pic.
