This is the second one that has died. Someone here said that user fourforty has a potential solution but I’ve checked his profile and tried the Search for finding the post but can’t.
A few things.
Dealer replaced first one. I understand that Lenco actuators get water in them and that that may be the issue. I see the Alert in diagnostics on the screen and tried resetting but it’s stuck in down position. The Lenco trouble shooting guide says to pull apart the clip and test it by linking the wire directly to the battery as it will bypass the switch. Of you reverse the wires it will go up and reverse again it will go down. But, I cannot see where that connector wire is located. It’s a little grey connector.
Anyone have any insight into this or am I wasting my time. These actuators SUCK.
A few things.
