Should I get this repaired?
  • Should I get this repaired?
    I ordered a new prop from ACME for my '13 X14V and had every intention on sending my stock prop back to ACME to get repaired. Under water, I could see/feel a couple small dings. Now that I have it on my kitchen table, I'm not sure if it's worth sending it out for repair.
    Sent from my Pixel 3 using Tapatalk
    Adding pics...
      Yes, without a doubt (my US$0.02).
      Doesn't seem like much (thus your post), but it doesn't take much to throw a vibration.
      As much as anything, I'd want them to block it and make sure it is on specification all across the prop.
      93 190
      (safe click)
        Thanks for the reassurance. I try not to let cost drive my decisions with my boats...I figure you'll spend the money to fix it eventually. It may just be a shaft or strut or something worse.
          Does acme offer free repair of the old one if you buy a new one like OJ does? If so, no brainer. If not, I'd say it depend on if its going back on the boat, or in the garage as an emergency backup... which it'll do fine for short time in a pinch. Just my opinion. I don't mind spending money, but I hate wasting it.
          Sent from my SM-G960U using Tapatalk
            They can fix waaaay worse than that.
            2006 MasterCraft XStar
            2006 MasterCraft X1 - Sold
            2003 Sevylor Caravelle 7' 6"
              Understood. My question was more "should" than "could" it be repaired. As waterlogged said, probably a good idea to make sure it's in spec in addition to fixing the small dings.
              I've got an OJ prop that came off my '83 that has all 3 tips bent over 90°. This too is getting repaired.
                If the prop had a vibration then I would get it repaired. If not, then I wouldn't.
                  Get it repaired.
                    Not to hijack the thread, but I have an OJ prop and I picked up a vibration last weekend at table rock. There were quite a few floaters out there so I assume I knocked into something.
                    My prop looks perfect. I bought a new OJ and OJ will "fix" my old one. Hoping it's just prop but paranoid it's something else... Apparent damage to my current prop is nonexistent.
                      Check with acme and see if they'll fix yours gratis - similar to OJ's program.
