I was flushing my boat with salt away (basically a soap that removes salt deposits) and noticed spam sop foam/bubbles coming out of the rear of the raw water pump (area right before it bolts to the pulley). I thought it was because I have a leak but then ran it with just water for 10 minutes and didn’t see a single leak. Is it just the pressure from the soap foaming up? Anything to worry about? Pump is not even 2 years old.
Raw water pump possible leak
Check gasket at base of pump, not perfect seal there, maybe the soap bubbles over lubricated seal and slid by.. maybe time for new seal soon
Originally posted by mrm2083 View PostI was flushing my boat with salt away (basically a soap that removes salt deposits) and noticed spam sop foam/bubbles coming out of the rear of the raw water pump (area right before it bolts to the pulley). I thought it was because I have a leak but then ran it with just water for 10 minutes and didn’t see a single leak. Is it just the pressure from the soap foaming up? Anything to worry about? Pump is not even 2 years old.
