Ilmor oil filter holder - do you like it?
  • Ilmor oil filter holder - do you like it?
    I'm sick of the pain in the butt oil filter location on my 209/LTR. I've tried the milk jugs, zip lock bags, and other tricks. With the routing of the shower and blower hoses on mine, it just doesn't work. So, I'm determined to do a remote oil filter install when I change it before winter.
    I like the look and functionality of the Ilmor inverted filter holder: https://parts.ilmor.com/shop/base-en...-filter-mount/
    I could fab a mount and it would sit behind the starboard cylinder head. Then use a remote filter adapter and some hoses with the appropriate fittings. Questions for those of you with this mount...
    Do you like it?
    Do you attach a hose from the filter holder drain thru the boat drain plug only when changing oil, or is it permanently attached with a threaded fitting like the oil pan drain hose?
    Do you like it?
    My 2018 with the 5.3 GDI came with the Ilmor inverted filter holder. I like it better than the filter being impossible to reach. The factory didn't attach a filter holder drain to the oil filter mount. Usually I can hold a paper towel under it to catch any oil that overflows from the filter into the mount's funnel.
    The engine pan still has an oil drain hose that extends but is not attached to the boat drain plug. I usually connect a threaded fitting for my oil pump to the drain hose and pump it out that way. It's been the cleanest method and quicker than letting the oil drain out with gravity.
    (Previous- '08 X2 w/MCX)
    www.chesnuttech.com
      I love it. Only 1-2 ounces comes out of the filter and thru that little drain hole, since the filter has a rubber check valve on it. Make sure you get filter with this feature.
      Just hold a 1 qt oil bottle or 16oz water bottle under it.
        on my old 05 supra ssv it had a remote oil filter similar to what Ilmor has. I loved it and never had a mess and made changing the oil a breeze. on my 07 x2 it is a serious pita to change.
          Thank you, exactly the feedback I'm looking for!
            Awesome, thanks! And also thanks for the write up on the tr7. Works great!!
              Throw a 1 pint mixing cup under the drain and toss your filter in it after.
                The plus:
                • Easy Access
                • I add a small piece of hose to the drain into a cup
                • No Mess
                The Minus:
                • Remote lines hold dirty Oil
                • No matter How hard I try, even when pulling the filter first @ shut down
                • I always have 1/2 to 3/4 quart of dirty oil I can't remove
                • I use a Harbor Freight Compressed Air extractor, & still can't get 4.5 quarts out
                  Punch a hole in the top of the filter before you remove it. That will help drain more oil out of it before you remove it.
                    Do you like it?
                    The relocation kit has a plate that blocks the oil coming out of the bottom (where the filter would go) and has in/out ports, like the fitting for an oil cooler. The kit should come with everything you need, but if you don't like changing the filter now, you'll really hate installing that plate. The good thing- you'll only need to do that once.
                    Mercruiser has the same parts- it doesn't need to be from any particular manufacturer.
                    Personally, I think all vehicles should have this- cars, trucks, boats, etc.
                    https://www.amazon.com/Star-brite-Bi.../dp/B00FS4LKMU
                      Jim, I was thinking about using this product to attach to the block. https://www.improvedracing.com/low-p...r-env-191.html
                      Any experience with something like this?
                        You need a relocation kit, not the adapter.
                        The price for the one in the link seems too reasonable- if it's accurate, I would say it's a no-brainer for anyone who's tired of the contortions necessary to change their oil. For that matter, I might get one for my van because I need to jack it up to do it and this would make it possible to have clean oil with shorter intervals because the filter could be changed without much work. I used their vehicle check to make sure it will fit the cast iron Chevy engine in your boat by using the '90 Silverado I had and this is the correct part. If you really want the most filtering capability, use the larger PF-1218, rather than the short PF-25 (these came with Pennzoil PZ-3, which is their PF-25 equivalent).
                        https://www.summitracing.com/parts/s...make/chevrolet
                          I'm basically making my own kit, because I want to use the Ilmor filter holder. So I need an adaptor for a SBC, some custom fit hoses, and the Ilmor holder.
