99 XStar Restore - Progress Tracking
  • 99 XStar Restore - Progress Tracking
    I have recently reacquired my 99 XStar and will be attempting to restore it. Its in pretty bad shape and I am using this thread to document and track my progress. I also want to use it as a repository for any modifications done to the boat and a place to leverage constructive input the other folks can share.
Name:	Engine Right 2.jpg
    Ecm
    I have been told that the ECM will not hold its config any longer nor is this part manufactured any longer. Currently looking for someone or some company that can refurb this ECM, locate one that has been refurbed, or locate someone that has this model ECM they would like to sell (as long as it is working).
Name:	ECM Attached.jpg
      Good luck with your project. Lots of help here.
        https://www.ebay.com/itm/284301197870
        Not cheap but looks better than the one you have. One in your picture looks like it was submerged.
        99 MariStar 230 Sport LTR 330
          Check with these guys on the ECM: https://www.technicalservicesin.com/
            I saw that one online as well and have it marked as an option if I can't find something a little less pricey. yeah, my ECM looks like hell...all corroded...never submerged though. I appreciate the assitance
              Thanks...I will check with them as well. I currently have an email out to Indmar as I found another thread on TT that said Indmar tested their ECM and if it was found to be a goner, they provided a compatible replacement...Sounded like a good option to explore. I will check with these guys as well.
              Appreciate the input
                Following. Congrats. Looks like a lot of work ahead, but will pay dividends.
                ¡Viva 205V!
                2003 X2 MCX
                  Update on the ECM Replacement. I reached out to Indmar direct to see if they could assist, based on a separate post I found on TT. Indmar responded quickly to my inquiry but were unable to assist in replacing or refurbing. They did point me in the direction of Mefiburn to see if they could assist. Next step is to reach out to Mefiburn. Email response included for my reference.
                  Unfortunately we no longer have this ECM. You can try & get one from www.mefiburn.com
                  OBD Diagnostics - MEFIburn
                  The Complete MEFI ECM Solution - Tuning, Data Logging, Diagnostics for MEFI1, MEFI2, MEFI3, MEFI4, 4A, 4B. Our Marine EFI (MEFI) Scan & Tune TM system allows you to download the internal MEFI programming to your PC or laptop with our MEFIburn TM program, change the operating parameters of the controller, and then reprogram the controller with your modifications.
                  www.mefiburn.com
                  J.T. (John Todd)
                  GM Legacy Technical Support/Parts Specialist
                  Indmar Products
                  5400 Old Millington Rd.
                  Millington, TN 38053
                  Office: (901) 353-9930
                    Spoke with Mefiburn and they are able to run a diagnostic on my ECM ($80), if repairable they will repair it ($200-$300), and if unrepairable they can replace it ($1795). Shipping ECM on Monday. More to come
                      Ecm - Mefi
                      The folks at Mefiburn were great. They said there is absolutely nothing wrong with the ECM and not sure why the folks that serviced it thought there was something wrong with it. They are sending it back with the software to run real time diagnostics once I get it hooked back up. They stated the most likely culprit would be a bad coil pack not sending an return RPM signal. They said if it is that, to avoid buying a new coil pack from Indmar and go to a junk yard and pull on of a '90s model Cadillac...they are the exact same.
                      If I have further problems and need some help from them they told me to give them a call and they would be happy to help. Great vendor if you ever have problems with any older ECMs our there.
                      More to come
                        Cleaned Up and Moved to Garage
                        The wife did a great job giving this thing a bath and knocking off about 80% of the grime. I think she is wanting this boat ready for 2022 season! All Seats and Backings must be replaced...All carpeting must be replaced...I found a concerning crack in the flooring underneath where we ripped up carpet. No time to worry about aesthetics, just need to get her running. Awaiting the return of my ECM from Mefiburn. Tower off and stored in the garage through the winter
                          Great looking project! I just finished up (as much as I plan to do) a 99' Maristar 210 with the Corvette LT1 that had been flooded. Lots of electrical work and testing, along with bringing old chalky gel coat back to life and re-finishing the swim deck. If you have questions, I'll do my best to answer. Tons fun to be had, so make sure you take your time and enjoy the process!
                            Appreciate it!...This is my first go at something like this. Im hoping to make some magic happen. I may be reaching out. Thanks for the offer!
                              Same offer from me, I have the same engine in a very similar boat. Although mine has never been used as a submarine like it looks like yours was.
                              2000 Prostar 205V
