BF Goodrich Trail Terrain Review.
  • BF Goodrich Trail Terrain Review.
    As most you know I blow through tires and milagr on my trucks like crazy. So here’s another tire review. Essentially a newer category of tire. Gives you the looks of an AT with then mileage , noise , ride comfort lt , and mileage of HT. Exactly w tire I would love.
    I’ve reviewed more than few AT’s so here we go. I have roughly 15k on these new BFG’s.
    This new BFG Trail Terrain tire is empty we can be. Highway noise is minimal. Very comparable to a Michelin Defender LTX M/S ( which tire I love performance wise.). Handling is great very similar in stiffness in turns and what not. Looks amazing. Bumps and potholes are absorbed very well. I get same gas mileage as the Defenders. On city roads with potholes galore they jet just not more than the defenders on the big ones. Snow traction is great. Just as good as any AT I’ve run. Wear is great. However I also rotate regularly
    Now for the negatives.
    This tire is slick as all heck in wet pavement. I’ve never owned a tire that slipped as much as this tire and performed so poorly on wet pavement. It’s mind boggling how poor this thing performs and imo almost dangerous.
    it’s a shame this thing is so extremely terrible on wet pavement because the positives in all the other aspects are impressive.
    FALKEN launched a direct competitor to this BFG Trail Terrain called the Wildpeak A/T Trail. I’ll probably check that out for my daughters terrain here shortly. For now tho I definitely wouldn’t recommend this BFG Trail terrain for anyone that sees wet pavement consistently.
    CURRENT: 2008 SANTE 210 w NSS
    2000 Mastercraft Xstar
    2003, Ski Centurion Cyclone
    88 2001 Nautique
    Thanks for the review, another tire to avoid using. Wet tire grip is more important than ever with the torrential rain here.
      I think the same thing on my nitto ridge grapplers. I don't know how they can be so awesome on snow but so horrible on wet roads.
        Snow and wet have almost opposing characteristics for good performance. Snow is much closer to A/T while wet is much closer to summer/slicks. For snow, typically harder compounds that won't harden in sub-freezing temperatures and large blocky treading is optimal. For wet, soft compounds that typically harden in sub-freezing temperatures and just enough siping to prevent hydroplaning at whatever target speed and being otherwise slick is optimal.
          A softer compound with siping works well on snow and ice.
            Not as well as blockier treads would. Less contact surface area typically helps with snow and ice traction, while more surface contact area helps with wet (and dry).
            Soft tire compounds that provide the best summer dry and wet traction harden (get stiffer) in sub-freezing temperatures, losing traction quicker as temperatures drop than all season and snow tires. Well, you generally won't find summer tires for trucks but they are available for many crossovers and smaller SUVs.
