I have a 2003 x2 (205v hull pretty sure) Ballast-wise I have the two rear lockers full (i think 750 ea), the KGB (I think 400), and the IBS (I think 550) any tips for the best/largest wakeboard wake? I usually fill the IBS and KGB and fill both rear sacks about half way I ride around 65'-70', going about 21 mph Thanks guys!
Weighting 2003 X2 for Wakeboarding
lakedrum03 With my setup, how would you recommend filling? The 205 does make a mean wake, and we manage to surf it as well.
21 is too slow. Fill all of that to 100% and go about 22.5.Aric
LONE STAR MASTERBASH 2022
Register Here
2019 XT22 - Ear Bleeder
2022 Sea Hunt BX22 CC
For Sale:
2020 Crest 240 SLC Tri Toon
- Likes 1
Just to clarify, when you say rear lockers are full (750 pounds you think), does that mean the hard tanks are removed and replaced with a larger bag? If it's just the hard tanks, you'll need more rear weight, such as additional bags. If they are 750 pound bags, you're good there. If you want a bigger wake, fill them all up. You can then tweak removing some out of the front/rear based on the shape you like.
There are two major downsides to filling them all up.
1. You are probably going to have to increase speed (or shorten rope length) to keep the wake from curling over. The problem with shortening rope length is the wake is already pretty narrow on the 205V hull.
2. When you come off plane, the wave will come over the back of the boat and soak the rear seat. You can counter that by leaving the boat in gear when you come off plane, and then goose the throttle as the wave approaches.
- Likes 1
Originally posted by bcd View PostJust to clarify, when you say rear lockers are full (750 pounds you think), does that mean the hard tanks are removed and replaced with a larger bag? If it's just the hard tanks, you'll need more rear weight, such as additional bags. If they are 750 pound bags, you're good there. If you want a bigger wake, fill them all up. You can then tweak removing some out of the front/rear based on the shape you like.
Originally posted by chrislandy View PostGet a load of weight up front and in the centre to bring the bow down. It will also clean the wake up, help with steering, throttle response / general handling. I'd start with about 1/3rd of the rear weight from centre forward and increase from there.
The 205 hull works best when "lowered" rather than stern down, it's trial and error, but you can get some lovely shaped wakes by balancing the boat rather than having all the weight at the rear. I've never had to ride faster than 20mph by doing that.
We used to have the 205 DD (same hull, different engine location) and put 1500lb fat seat at the back, fill the tank, 300lb tubes down each side of the engine, 300+ up front in the bow and a 150 tube down the through screen walkway, then 5gal containers moved around the boat (2 or 3 up front and a few dotted around) to balance the wakes once we were moving.
- Likes 1
Originally posted by Trhodes View Post
you are talking about starting out fill the rear bags (1500 lbs) then split about 500 lbs between the bow and the center locker? The water is going to be cold but I plan on taking her out this weekend
Originally posted by bcd View PostNo, lead doesn't rusty, steel and iron do.
Originally posted by Mainely Wake View Post
Lead ballast bags do not contain any lead, they are usually filled with recycled steel. I was just curious if anyone had experienced staining, if everyone just removed the bags when not in use, or if people were storing them in waterproof containers, or something else entirely.
