Show us your shine!
  • Originally posted by Maristar210 View Post
    Great looking truck!!
    Thank you Sir.
    1989 Prostar 190 351 sold
    2008 Prostar 197 LY6
    • A little magic yesterday in the FL Keys Ceramic is for real
      • Originally posted by Prostar 190 View Post
        Just applied some Griot's garage Ceramic 3 in 1 wax as a top coat to see how well it holds up.
        Hi. Based on TT advice I used Roar Speed Gloss on my Black hulled X7. It took about an hour and a half in application and polishing. When it was done on the lift it looked fabulous.
        An hour later after skiing and then natural drying out back on lift the watermarks etc were back and the "like glass shine" was very diminished.
        Does this Ceramic polish "do any better in terms of sustained pre and after use shine and reducing the dreaded Black gel coat water marks". Also is there any special application technique required?
        I should mention I am in the UKso the boat is NOT in high temperature sustained sunshine.
        Any advice appreciated
        Ian
        • Originally posted by eurosysytem0 View Post
          Ian
          Bump Please
          • Wolfgang Swirl Remover, Wolfgang Sealant, then Griots 3-N-1 Ceramic Wax. Limited in storage so polished the G80 The aluminum trim up front and down the side got Swissvax Autobahn Wheel Wax.
            bret
            • Here's some shine on the water!
              • Do you need a traditional wax before using a Griots 3n1? Or can you move straight from a fine cut polish #2 from Meguar’s?
                I need to add some new decals from Domed # as well. Would you put them on before the 3n1?
                • Ummm.... wax on!
                  -Tim
                  • I think you’re saying you’re not a fan of the ceramic!
                    What wax would you recommend?
                    And then back to the second question… Wax before or after the decals?
                    To put things in context, I’m about 8 to 10 hours into wet sanding on this boat.
                    I’m now diving into a Med Cut Cleaner on a Med pad. Followed by a Fine cut polish with a fine pad.
                    I’m over it. I need to be done. I need wax, decals and a beer
                    Thoughts appreciated
                    • Originally posted by williamsatown View Post
                      Do NOT wax before you put new decals on your boat. In fact, you need to strip down any wax that is on the boat and then clean the area with rubbing alcohol and let that dry before you apply the decals.
                      -Tim
                        As far as wax I've had great luck with McGuire's flagship wax. As already stated you don't want wax on it before applying decals.
                          Ummm.... wax on!
                          Looking good!
                            Ummm.... wax on!
                            Looks totally nice! Well done
                            • I'm doing a 2014 ProStar in a few days and I'll post up results but figured I'd post this up...for those small "sunshine" marks, using a polishing pad, about 4000rpm to spread the product on 24"x24" area, then increase to 5500 or 6000rpm, make 6-8 passes, vertical / horizontal, overlapping about 50%. The Wolfgang Swirl Remover does a great job.
                              Now Ghost chipped to 455hp
                              Camaro looks great Tim!!
                                Ummm.... wax on!
                                Looks fantastic!
