Originally posted by Jesus_Freak
View Post
It does need to be 65f at a minimum.
You can make sure that the oil is dry enough and that you are using enough water by conducting a simple test. First, determnine the coefficient of friction of the sand paper across dry, oil free teak by calculating the amount of force required to pull the sanding block across a preset distance. Then, carefully spray water on the surface of the oil free teak and repeat the test. Now, apply oil in a sealed room at 80f with .05% humidity and let it dry for two months. Then, calculate the coefficient of friction without using water. Next divide the coefficient of friction of the sand paper across the dry teak oil by that of teak with no oil multiplied by 3.14 multiplied by the coefficient of friction when using water on teak without oil. If the result is within .0631% then the oil is dry enough and you are using enough water. Simple, really.
