I did 150 then 220 grit sanding and one very heavy coat of Starbright Gold. It looks good, drying a little more in some places than others, but it looks fair to this point. Some say "wetsand" with 400 grit before another coat. Some say clean with mineral spirits and 00 Steel Woo before next coat. I am thinking about putting another coat of Starbright with the Steel Wool as an applicator? Any thoughts on why this is a good or bad idea?
Mine just seems very dark. I'll keep going and it'll either get Better or worse
Tapatalk
I only sanded the end grains, not top or bottom. Didn't want it TOOOOO smooth as kids would slide off as happened on our Ski Nautique. Won't happen on the MC. Don't get me wrong it is not rough, just not like glass. If you keep going with more oil, chances are it will get even darker. I let mine dry for several days and before the last three applications, I only added a light coat of oil where the wood turned to a slight ashy color. Eventually it will be uniform all over.
Hope that works for you as well.
Not saying you guys are doing anything incorrect, but I have had best results with linseed oil and mineral spirits (combined). Teak oil and other mentioned products have given me darker results over the years. This last time around in 2012, I used the linseed oil mixture and I'll not go back to teak oil or other.
Took me two coats and my board looks primo....
Your boards look fine and the teak and Starbright will weak down in a few months of lake use, so consider the aforementioned concoction.
If you're not 100% satisfied, I'd consider stopping where you are and use the board until it needs another treatment, then try the linseed oil/mineral spirits. Several folks here have the same or similar testimony of which I speak.
I'm not sure what sanding gets you but it's not my board to say. Most of these slicky-boy finishes are for show and IMHO, not practical for use, but that's me. I like functionality. I pressure wash my board once a year, no sanding.
$0.02
I'm always open to ideas especially when it's cost effective. That's why we are here on TT.
The Starbright method is the first I tried and it worked, but it does cost about $18.00 for each of the three steps. What are the proportions of your mixture? My Nautique lasted two years without a reapplication; on a lift under a conopy. So the next time I would try the linseed oil/mineral spirits mixture and see how that works in Wisconsin.
Maybe I put to heavy of coats on mine.. I mixed linseed oil and mineral sprits 75/25, first coat looked great wet but soaked in and the wood was about halfway back to its old look.. I'll let it set a couple weeks and decide from there
From what I have read, little bits of the steel wool could break off and get into the grain of the teak, which would then rust and cause the teak to permanently stain. Some people use it and seem to have no problems though.
That makes sense if you want to sand. I don't like sanding; so I don't.
At the risk of sounding a little (or a lot) stupid, wouldn't that get to be be a little slippery??
Hey all,
Still looking for anyone out west who might be interested in swapping their teak platform for my black fiberglass - '06 X30. Any interest or leads, let me know. Thanks.
If an X1 is the same I would be interested maybe but Utah is a long way from Texas.
