Originally posted by DStockton24
View Post
Originally posted by DStockton24 View PostHow much linseed oil do I need? 1 gallon or 1 qt? Since I'm in no hurry for cure time does it make a difference between raw or boiled and will one give me a better result than the other? I am wanting to go darker.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Originally posted by ryancassidy View PostBoiled Linseed Oil and Paint Thinner....
Mixing these two actually works well for several things outside of just Teak (ever needed to refurbish black plastics? :-) ).
This is basically the same stuff that you find in Teak Oil to my understanding, but cheaper and in bulk.Last edited by CantRepeat; 11-03-2016, 03:17 PM.-Tim
Making boomers great again!!Boomin'
I have some leftover Brazilian Ipe, so I am toying with this idea of a new teak deck as a winter project.
I figure using the current fiberglass platform and brackets as a template should make everything pretty straight forward?
Anyone have experience doing it this way?
Originally posted by IBR View PostI have some leftover Brazilian Ipe, so I am toying with this idea of a new teak deck as a winter project.
Originally posted by harborseal View PostHas anyone undertaken repairs on a split part of the platform? Mine is split on the top so that it
could pinch someone or cause a splinter. Perhaps seadek placed over the platform? Is that a possibility?
I think I read somewhere here you could replace the entire platform for $300.00+ change. That's if you choose to go new. I think you can make it look just as nice with a little effort: and you can say,"Look what I did".
Good luck
Sticky
Originally posted by DStockton24 View PostAfter putting a couple of linseed oil on my deck and cured for months, its kind of sticky. Is this normal? Can I fix it?
Sent from my SAMSUNG-SM-G930A using Tapatalk
Sent from my SAMSUNG-SM-G930A using Tapatalk-Tim
