    DA sander with 220 to strip off whatever was on there before, starbrite teak cleaner, then brightener.
    80/20 linseed\mineral spirits with a brush and wipped it off after an hour. Not so sure I'll even do a second coat.
    And make sure you wipe it down with a clean towel after an hour or so after putting the oil on. Then out in the sun!!
    -Tim
    • I'm refinishing a Sanger teak deck that hasn't been touched in years. I started out by pressure washing the platform, then used Starbrite cleaner and finally Starbrite Brightener. It has come a long way but I still have some black stains that I can't get out of the wood. I've read that it's most likely mold/mildew and wood bleach may take care of them. Any other recommendations? I intend to sand the platform with 80 then 120 grit before oiling it.
      • Get some sand paper on it. Use some 80 grit then down to 320 and then clean and brighten again. Use the 80/20 afterwards and it will look great.
        -Tim
        • I'm pretty satisfied with the results after using a DA sander on it today, 80 grit followed by 150 grit paper. I still have to sand the crevices and corners with a sanding block before I oil it.
          • Looking much better!!
            -Tim
            • Team swim platform
              Spent the whole winter looking for a teak swim platform for my stars and stripes with no luck. Does anyone know someone who has one for sale? Sure would be a nice addition.
              1981 stars and stripes -powerslot
              sand with red metalflake stripe
              • Teak World in Lebanon TN can make one for you.
                • Refinished my swim deck, turned out pretty good I think.
                  • Beauty
                    • New boat. One season under our belt.
                      Is this a full sand and re stain or can I get away with a pressure wash only?
                      • 80 grit the hole thing and then 75/25 80/20 which ever you like and you'll love yourself for it!
                        -Tim
                        • I used the 3 step process from Star brite on my 99 Sportstar deck.
                          First step was knocking it down with 250 gritt
                          Last pic is the final coat of oil
                          99 Mastercraft Sportstar
                          • Originally posted by 99mastercraft View Post
                            Awesome... You cannot beat the three step system. Now cleaning (step 1) and then the oil (step 3) is probably all you will need to do. It worked for me... Nuff said...
                            • Looks good!
                              1989 Prostar 190 351 sold
                              2008 Prostar 197 LY6
                              • Appreciate it guys. I'm anxious to see how well it holds up
