  • Originally posted by Miss Rita View Post
    If I was to through-bolt the platform I'd use stainless countersunk machine screws, I think it's a nicer look than carriage bolts. Brass screws would add a little bling.
    Good thought. I will post pics of what the almost PO did
    2010 X-15
    SOLD 1994 205
    2011 Pathfinder
    2016 Ford Flex
    3 kids, a wife, and a boat dog
    1 kid in college
    • Dry time before putting teak in water
      I just finished putting a coat of teak oil on a swim deak I disassembled, cleaned and sanded. I have a question I was not able to find reading the threads. How long does it need to dry before I can put it on the boat in the water? If its been drying in the sun most of the day is it ok to go skiing with it this evening? Or does it need more time?
      • Originally posted by sticknrudder View Post
        You're better off putting on a few light coats rather then one heavy coat. They'll dry quicker.
        That said, if it's no longer tacky to the touch you can get it wet no worries.
        -Tim
        • OK - I have what is probably a dumb question but I can't seem to find the answer. We have a 2016 X30 w/teak platform. Was going to oil it this off season. Is the best way to remove the swim platform to unscrew from the brackets? Looks to be what most have done in the pictures I see posted. The platform does not appear to remove easily with the brackets left on. It folds down, but doesn't seem to remove altogether from what I can tell.
          • The platform will remove with the brackets in place. There is a pin and a bolt on each. Comes off easy. The bolt has some sort of acrylic washers on each side of platform bracket that can be a pain to re-install. (not enough hands if you're alone) I'd be leery of unscrewing the screws. They will never be as tight when you re-install them. But for a one-time removal, I think they'd be fine. But I'd remove the platform with brackets.
              I'd agree with this.
              Originally posted by sp00ky View Post
              Yeah it's what I was thinking. Any opinions on teak plugs? Could that work?
              I don't know that the teak is thick enough to countersink a bolt and install a plug, and have it as strong as I'd want it. But it could be done. But then it is permanent, unless you drill out the plug to get at the bolt head for a future removal. Or if you're thinking carraige bolt, you'd need to countersink even further than the flat head screw-head bolts.
              • Originally posted by harrisdoggy View Post
                I just fold down the platform and oil the back third of the platform then swing it up and finish the job. You can also apply painters tape on the transom if you wish. I apply with an old Sock as to not make a mess and leaves a nice finish.
                1989 Prostar 190 351 sold
                2008 Prostar 197 LY6
                • Awesome - thanks for the info. Swim deck looks great!
                  • Sold the boat a couple of months ago, but loved the teak deck I made:
                    —Sky
                    2006 X-1 Pumpkin Orange SOLD
                    • I miss teak. It's on my list for the next one...
                      • '02 Maristar 230 teak re-pop
                        Here are photos showing the result of my rainy Sunday efforts. The boat is an '02 Maristar that had set neglected for quite a while. I have committed to bring it back around. The swim platform is an easy one......just elbow grease and time. Teak is so wonderful. Notice the bird droppings on wood in the B4. Yes, i cheated a bit and used a planer. I was super careful and ended up losing less than one mm of thickness.....still cheating though. After photo is with first coat of 80/20 Linseed and mineral spirits. Several more coated to come. Happy Thanksgiving to all!
                        David in SC
                        • Hey Guys,
                          the X2 is nearly ready for Season ´20 and so I started with some litte projects on my Ski Nautique, wich gets sold in spring.
                          Started with the refurb of the Swimplatofrm
                          Greets from Germany,
                          Felix
                          • Practiced social distancing this weekend and gave the X23 some much needed attention.
                            Here is a before picture
                            • And after....
                              • Originally posted by Mastercraftdave View Post
                                And after....
                                Spectacular!
