Originally posted by Mastercraftdave
View Post
Originally posted by waterskier360 View Post
X25 had teak and we loved it , nxt22 was glass and it was ok . our new toy we go back to teak . think it looks nicer and more classy .
Originally posted by lakedrum03 View PostThat looks great! What is the wood you used for the contrast inlay?
that looks awesome . hope its not too slick
what do you guys use to keep them up?
Sent from my iPhone using TapatalkLast edited by waterskier360; 03-23-2020, 05:36 PM.2012 GT205
2011 X25
2019 NXT22
2020 NXT20
Originally posted by bluprint View PostWith the downtime and a little motivation from this forum....I took care of my platform. Sanded 60/80/120/200/400/600 top and bottom. Boat is 10yrs old and needed it. Just threw the oil on and have it curing. Thank you for all the information!!-Tim
Making boomers great again!!Boomin'
Followed a lot of the advice in the thread and tackled my ProStar teak last weekend.
- Started with the nervous task of disassembly. Go very slow removing screws because if any are at an angle, they can chip a piece of the platform when coming out of the recessed hole.
- Lay everything out exactly as you disassemble it. Be MOOCD about what goes where throughout the process.
- Next I hit everything with 80 grit sandpaper on a belt sander. Got everything to an even wood color. Wear a face mask and glasses. The dust gets on everything and is not healthy to breathe.
- Then I touched everything with 120 grit on the belt sander, being very careful on the ends and corners.
- Next I blew all pieces off with air compressor.
- Then I wiped everything down with a tack cloth to remove any remaining dust.
- Then I coated everything with Star Brite teak oil (I chickened out on the linseed oil).
- Several more coats with time to dry in between before re-assembly.
- Finally re-assembled with new stainless hardware, and put 2 more coats on while letting bake in the sun.
Turned out nice for 22 year old wood. Thanks everyone for the advice!
Originally posted by WeekendsR4Me View PostFollowed a lot of the advice in the thread and tackled my ProStar teak last weekend.
Turned out nice for 22 year old wood. Thanks everyone for the advice!Prior boats - (3) X14's, (3) Prostars, and a Tristar.
For those doing the linseed oil thing, do you find that as long as it is maintained, you don’t need to do regular power washing or sanding etc?
I’m on second season for this method and just added the oil last night and it looks good, I did zero prep, other than hitting pretty hard with air. Boat / platform sees very little sun, all is covered.
Originally posted by MIskiboat View PostFor those doing the linseed oil thing, do you find that as long as it is maintained, you don’t need to do regular power washing or sanding etc?
