Engine Box Insulation
  • Engine Box Insulation
    Can anyone provide some links/info for some replacement engine box insulation.
    The stuff on my 94 is in horrible shape and I want to tear it out.
    I have been unsuccessful using the TMC Google search but I am sure this has come up here before.
    Thanks.
    94 Prostar 190, LT-1, Powerslot [SOLD]
    sigpic
    Here is a thread, http://www.mastercraft.com/teamtalk/...ght=insulation
    Use the Advanced Search feature here on TT and insert key word "insulation" and you will get this list, http://www.mastercraft.com/teamtalk/...archid=1792029
    Charter Member Number 1
    Quote: 2RLAKE,
      Thanks No1, I actually found that thread already but all the links were dead.
      I really want a the name of the insulation product or a link to it so I can purchase some.
      Overtons does not seem to carry the insulation that East TX used in his project 4 years ago. I have also checked West Marine with no luck.
      sigpic
        I would be interested in getting some insulation also.
          I looked for the stuff recently that I used to answer a question for someone on another forum and came up empty. You might want to call Overton's and see if they can point you in the right direction on who the manufacturer was.
          Previous: 1993 Prostar 205
          FAQ
          Be kind. Have fun.
            You may find what you need here, http://www.insulation4less.com/prode...D=179361271012 or even check with a local insulation contractor in your area yellow pages.
              "DynaMat" is the sound dampening material used by high-end car audio shops. They put it in doors and back gates. Under or behind carpet and upholstering to reduce vibration from speaker. Comes in sheets of various size and thickness. I too remember a kit, but can't find it.
                I have seen the DynaMat, a bit out of my price range. Thanks.
                I think I found some insulation that will work.
                http://www.mcmaster.com/#9160k4/=21k79d
                The foil faced stuff looks just like what previous people had used.
                sigpic
                  This is what I will be using next year. My foam from the factory has never stayed put. I am sick of it, so I will be installing this stuff.
                  http://www.secondskinaudio.com/vibra...lifier-pro.php
                  -Cameron
                  2007 ProStar 197
                  1996 ProStar 190
                    I have been told that this stuff works well. http://www.lowes.com/lowes/lkn?actio...025&lpage=none
                      Been told by many that that stuff does not do well, because the adhesive is a tar based product and as the heat increases, it's effectiveness decreases and makes a nice mess of everything.
                      -Cameron
                      2007 ProStar 197
                      1996 ProStar 190
                        Maybe I should have added not to use the adhesive they suggest. From my source basically you use a reverse rivet to hold them in. Think about the underside of your cars hood. The attachment device uses extremely strong adhesive to stick to the inner box. Looks like a short upside down nail. Stick the sharp point through the insulation, then cap with a inch or so diameter cap.
                          The installer used contact cement to secure my replacement insulation. Never had any trouble with it coming down.
                          FAQ
                          Be kind. Have fun.
                            Found this, any opinions?
                            http://www.lobucrod.com/newinspics.html
                              Sorry I don't have a complete answer for you, however I purchased mine from a local RV store. It was the exact same stuff that Overton's was selling, and was half the price. I won't be able to get the information for another week, however will get the manufacturer and contact info for you when I get back home.
