Dash panels- 88 Prostar
  • Dash panels- 88 Prostar
    The mount holes on my dash panels are cracking, so I figured I'd CAD up new ones and fab them. Right now, I've only got the left panel drawn out, I'll have the right side switch panel done early next week. I have a laser cutter in my classroom, and will make a trial set out of plastic, but I might have nicer ones done out of sheet metal and powder coated, depending on cost.
    Top two holes are 2" in diameter, I have a depth gauge and hour meter there, the lower holes are for horn (left) and ignition key (right). The switch panel will be a copy of the original. I'm thinking for the switch labels, I might see if I can have vinyl letters cut, rather than trying to mess with silk-screening. (Possible to do on metal, but adds to cost.)
    Once I get them done, I'll start a thread in 'For Sale' if anyone's interested in buying a set.
    G
    As long as it's Lexan, they won't crack.
    Anything less will crumble.
    Hint - LED
      The laser cutter will cut anything combustable. It's not too happy with some plastics, because of the particulate matter that comes off- I was leaning towards black lexan, so it looks factory. Wouldn't be too hard to do something translucent instead, with LED backlighting.
      G
        Paper prototypes cut- assuming they fit well, I'll have plastic pieces cut Friday.
        Then it's just a matter of getting vinyl letters for labeling the switches.
          Tried something new for a prototype- got some engraving stock- black with a white underlayer. By setting line colors in the drawing and changing power settings on the laser cutter, I can cut through the panel on the black lines while only etching the blue text. Etching allows me to burn away the black plastic, exposing the white underneath.
          I still want to play around with aligning the text for the switches, but I really like how these are looking. I made a practice panel with a plain font, then found the Hemi-Head font. I forgot to take a picture of the actual panel, so I couldn't label the various reset buttons. I'll correct that tomorrow and run another set of panels (hopefully the final set).
          A little more playing around and I should have something that's a pretty reasonable replica of the original panel, but with a few personal touches.
          G
            /spĂ´rk/
              I would quite possibly be interested in this. I have a 1990 Prostar that Im restoring, and I need to replace these panels. The arrangement I have is different for the left panel. I dont have a depth gauge, although I kinda want to install one. But I also do have a safety switch there.
              Here's what it looks like:
              I would like what you have designed above with a cut out for the safety switch also. But I would like the panel to be black with white lettering. Is that possible?
              PM me with more info please.
                Thanks for the interest. I'll certainly make extra sets if people want to buy some.
                nkorep2: I can do custom plates as well, but I'd need measurements for the cut-outs and a layout. (pm sent)
                The image in my previous post shows blue text- that's just part of the drawing software. The coloring of the final pieces would look like the image below- a black plate with white text. The one below was made before I found the HemiHead font, but you get the general idea of what the final piece would look like.
                FWIW, I haven't done a cut on plastic with the HemiHead font, so when I get that done, I'll be able to show exactly what the final will look like.
                G
                  looks great, keep us posted, my '89 will be needing some tlc soon!
                    What a very cool process - this will definitely get me brainstorming on an old 78 S&S makeover.
                      OK- dash panels are done. The HemiHead font looks really good- props to whoever found that font and shared it. I know on my hull the word MasterCraft uses a combination of upper and lowercase letters, but I think all uppercase (but with different font size) looks better.
                      They'll be installed tomorrow, pictures to follow. :crossesfingers Hope I got all my measurements right. Realized that while I measured the hole diameter for the hour meter and depth gauge, I didn't measure the diameter of the trim ring. I left enough space for a 1/4" trim ring on each gauge, so I should be OK.
                      G
                        I'm interested
                        WE LIVE IN THE LAND OF THE FREE, BECAUSE OF THE BRAVE
                        Team MasterCraft Google Search Engine
                          Just a heads up for folks who are interested- since this is engraving stock (black over white), the edges of the panels are white. I don't think it's a big deal, but they will be slightly different from original.
                          G
                            Nicely done. I had a fabricator duplicate my panels on my 89'.
                            Anodized aluminum, engraved and painted lettering. These should hold up a little longer than the stocks
                              I thought about going that way, but the minimum charge was $150, and that was for a plain aluminum panel with cutouts. Powdercoat and lettering would have been more.
                              I'm not too worried about holding up, seeing as how my boat's 25 years old. If I get 25 years out of these new panels, that's good enough for me. I can always knock out another set if I need to.
                              G
