Steering wheel center emblem
  • Steering wheel center emblem
    Trying to find the center emblem sticker for a 1989 Prostar 190. I've attached a photo from the web to give an idea. Even a part no. I can use at a dealer would be fine, but dealers are not close around here, id rather buy online.
    Any help would be greatly appreciated.
    Mikeg205 might be able to do that for you.
    Custom wheel and tire packages
    Rebuilding Holley Carbs $249
    Rebuilt complete Holley Carbs $400
    sigpic
      Mike was unable to help, anyone got a part no from a dealer? My dealer says they can't look it up. Or somewhere to have one custom made?
        I'm working on making my own if anyone is interested, I had to buy some things in bulk.
          I have one similar. Fo freeClick image for larger version
            Hello Strreamline, I know this is 4 years later but did you ever make these? Would you have any these days?
            Thanks
              Thanks
              Domed Numbers makes this and I think they also make the sticker that you posted above. Don't hold me to that claim. I have seen it somewhere recently while looking for this below.
              93 190
              (safe click)
                They'll do different versions too - strongly recommend domed numbers - pick your logo, pick the colors and tell them the diameter you want.
                  What did you need to swap in the newer style steering wheel?
                    First get your old one off mine was STUCK had to use heat and a puller.
                    Once its off check if your wheel is splined or keyed to the shaft.
                    Then go to ebay and find a wheel you like that fits the type of shaft that you have.
                    Then my wheel came with blank center plates as well as a center for supra, malibu, and cobalt. So I ordered a new center cap with the logo I wanted.
                      The one I posted above is gone.
                        The 96 has the spline shaft.
                        The new wheel(s) can be found on fleabay.
                        Is is an easy swap. The adapter for the wheel to helm came with the wheel (the one I posted a photo earlier in this thread). Plug and play.
                        93 190
                        (safe click)
