Sorry to start yet another thread on Fusion head replacement, but so far I haven't been able to find an answer.
So quick summary.....
* My original system is a '15 X10 with the factory MS-IP700i head unit and two MS-NRX200i remotes.
* The head unit started to have intermittent power up issues so after a bunch of diagnostics and effort, I decided to replace it.
* after consulting with Fusion Tech support and reading threads, I settled on the MS-AV755 as the replacement
* My understanding was that this deck was compatible with remotes and all I would need to do is splice power wires
Here is the problem
* the new MS-AV755 comes with a 5 pin NMEA200 male connector.
* the outgoing MS-IP700i had a 8 pin female NMEA200 connector
* I haven't been able to find a converter cable
What is the easiest path? Do I really need to re-run my trunk from the deck to the remote?
Attached are some photos
Here is the problem
