Ok, since the 16pin connector speaker harness vs. the amp speaker wire bundle was resolved in the parallel thread I brought the final options for new system back to this thread. Here seems like to be the most probable options. Would like to hear what you think.
Replace current Clarion CMD4 HU likely with the Clarion M608 and possibly new wired remote...could get 6/8 pin DIN adapter and use existing wired remote with no LCD support...would likely just run new
in I/F and replace remote. The M608 has 4 zone capability so I could wire them with the bow, cockpit and towers all on different zones...could decide whether to put the subs on a zone or just added to the cockpit zone.
M800/8 = 100 W x 8 @ 2 Ω / 75 W x 8 @ 4 Ω - 14.4V
My math tells me that two speakers wired in parallel thus being a 2 Ω load driven by one channel of the amp, those two speakers would be getting ~45 - 55W for each speaker vs. 75W wired as a single 4 Ω...and the spec says 200W for bridged output of two channels.
One option would be to use the M800/8 and run the two bow speakers with Ch 1 -2 both at 4Ω to the amp per channel. Then run two of the cockpit speakers using Ch 3 and the other two using Ch 4 both sets in parallel as a 2 Ω load.
Could then use Ch 7 and 8 to drive the towers with each getting a channel and being a 4 Ω load to the amp.
Buy a second amp in same M series that could be used to drive the two subs...one now and a second one added.
This would allow me to replace two amps with two amps and get a sizable boost in performance, but without bridging to speakers and driving them harder...
To drive every speaker with bridged outputs would require a third amp.
Thoughts??
Thx!
Thoughts??
Thx!
