Help with amplifier
  • Help with amplifier
    Hey guys I have a problem with one amp not powering up. However when I take the channel rca lead out and place it in the pre out everything powers up. Then I just put the cables back to normal and it’s fine as long as I don’t turn it off.
    Assuming you have multiple amps I would try swapping the RCA Outs to the amps on the head unit to make sure a channel on the head isn't going bad.
      Can you share a picture of ‘normal’ wiring then show one of how you re-wire it to get the amp to power on?
      —Sky
      2006 X-1 Pumpkin Orange SOLD
        I to would like to see what you are unplugging and to where you are plugging it back in.
        Sounds like the amp is set to audio turn-on v's 12V turn-on.
