I have been thinking about installing a ported 10 or 12" sub in my 03 x2 I have seen people replace the stock free air clarion sub with a box, and other that have built a box in the bow and put a filler cushion on top to make a sort of play pen. I would like to do the second option and wondering what kind of tips you guys have. From the research I have done, it seems that the shape of the box does not matter as long as the volume meets the requirements of the sub. I would use medum density fiberboard, and would fiberglass over the MDF to make it water proof. If anybody has pics that would be really helpful.
Ported Sub Location in '03 x2
Originally posted by Trhodes View PostI have been thinking about installing a ported 10 or 12" sub in my 03 x2 I have seen people replace the stock free air clarion sub with a box, and other that have built a box in the bow and put a filler cushion on top to make a sort of play pen. I would like to do the second option and wondering what kind of tips you guys have. From the research I have done, it seems that the shape of the box does not matter as long as the volume meets the requirements of the sub. I would use medum density fiberboard, and would fiberglass over the MDF to make it water proof. If anybody has pics that would be really helpful.
I'd take the easy route and mount a 10 or 12" sub into the existing bulkhead. Go to the back side (inside the under-seat storage) and put in another (rear) bulkhead to close the space and as much so protect the speaker from anything sliding into it from the storage compartment. To me, it is that simple. And the effectiveness of the subwoofer to the common listener is spot on.
On another note, then comes an amplifier for the subwoofer...then maybe a second battery to power the (now) two amps (or not).
That said, I enhance the front seating area with two additional forward cabin speakers. Another easy-peasy install. Done deal. I did this (subwoofer, two additional speakers, two amps, and two batteries on an isolation relay) to a 205 a short while back.
The owner is happy with the results​
Best on the install. Keep it simple and easy.
Others here know a lot more than I do about this. I manage to get by and hopefully this will give you some idea and confirmation that your approach is viable and effective.
.Last edited by waterlogged882; 02-23-2023, 08:39 PM.
- Likes 1
Originally posted by Trhodes View PostI have been thinking about installing a ported 10 or 12" sub in my 03 x2 I have seen people replace the stock free air clarion sub with a box, and other that have built a box in the bow and put a filler cushion on top to make a sort of play pen. I would like to do the second option and wondering what kind of tips you guys have. From the research I have done, it seems that the shape of the box does not matter as long as the volume meets the requirements of the sub. I would use medum density fiberboard, and would fiberglass over the MDF to make it water proof. If anybody has pics that would be really helpful.2000 Prostar 205V
- Likes 1
