Suggestions for Mounting Remote on curve
  • Suggestions for Mounting Remote on curve
    I was wondering if anybody had a suggestion for mounting my Clarion MW1 stereo remote on the back of my 2002 X-30. The whole back end is curved and was ondering what people had done to deal with the gap. Thanks
    lazydog3,
    If it is a 1/16" or less gap for example, then 3M marine white silicone as a gasket sealer will do. If the gap is larger then use .25" or .50" thick white KingStarboard to make a contoured disc. KS, while impervious to the marine elements, is a soft material and easy to shape. Start with a wide and rounded file and then convert to a radiused sanding block by spray guing sandpaper to various diameter PVC tubes. A mixture of techniques, a few trips to Home Depot, a little elbow grease and plenty of patience.
    David
    Earmark Marine
    https://earmark-car-audio.myshopify.com
      Great ideas, thanks!
