Trying to sort out which set of wire go to each speaker in our 2001 205v. Anyone have a schematic or know the color coding? It should likely be the same as xstar and possibly other models?
In my 2003 x2, the green and purple wires go to the rear speakers and the white and grey ones go to the bow speakers. I can't remember which ones go to which speakers, but it's pretty easy to figure out. For the rear ones, you can just remove the seats and look. For the front one, just disconnect one set of wires to figure it out.
Thanks!
Ross
If it conforms to the head unit's color code (and it should):
White/White with black= left front
Gray/Gray with black stripe= right front
Green/Green with black stripe= left rear
Purple/Purple with black strips= right rear
Jim,
Thanks! Turned out this was the same as mine and wired up per above. Worked perfectly! Thanks so much everyone!
