Ordered! Thanks!!
Wiring stereo to stay on from key ON to ACC
I have an older boat but wired mine to the perko.... It can be always on unless i turn off the perko. Most of the time during the season the stations stay programmed etc...
Sent from my SAMSUNG-SM-N920A using Tapatalk-Cory 2.0ld
98 Maristar 225VRS - "Frankenstar"
91 PS190 -Sold
RIP No1
Originally posted by eecyclone View PostCorrect, as long as you aren't cranking the engine for more than your timer duration (3 seconds with my programming)
Originally posted by Skyskiguy View PostGot mine installed today. Works as described when switching from Run to Acc and vice-versa. But it does not prevent the radio from cutting out when cranking the engine. Is my ignition wired differently? Or has everyone else experienced the same results?
Sent from my SM-G920R6 using TapatalkEveryone Dies, but not everyone lives
2004 Prostar 197, ACME 843
awesome idea!
i was just about to make a thread asking how people go around this idea. the kenwood deck in our boat likes to lose BT connection every few key cycles and can get kind of annoying after an afternoon of key cycling to keep having to re pair the phones.
i guess the other option would be just to wire the deck to battery, but im sure itd only be a matter of time before someone forgot to kill the batteries after putting the boat on the trailer...
If you have 2 batteries you could install one of these and it should prevent the radio from quitting while starting the engine.
https://www.bluesea.com/products/761...12_24V_DC_120A
