I had a box made for my 197. It is in kind of an L shape. Works out pretty good. It holds a 10" sub. I can get dimensions for any one that wants them.
Subwoofer Installs...Let's see them!
Originally posted by Prostar19I had a box made for my 197. It is in kind of an L shape. Works out pretty good. It holds a 10" sub. I can get dimensions for any one that wants them.Originally posted by TX.X-30 fanSay yes to cheap beer---- no to ethanol.
Are these dimensions for a SEALED enclosure that would work with say a Clarion 10" Sub? You think it could be built right on the back of the factory kick panel in front of the driver?MY PHOTO ALBUMS
sigpic
Originally posted by Ric View Postwhat would have been a great subwoofer install pic is one of Ric... contorting to get a 10" sub enclosure mounted in the very very tip of the bow of a 190!
That is inching up there to screw in the strap type mounts from the sub box to the rubrail on each side... Crawling between the MTS ballast tank and the bulkhead wall uuuuughghhhhgh... Now that would've been a pic!Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
The 197 with a 12" sub. The two channel Clarion amp is attached to the back of the sub enclosure. The two amps on the side wall run the hull speakers (one four channel) and the four Polk Momo's on the tower (the other four channel).
I would add pictures of the X2, but I think, Shawn, that you know what that one looked like under the observer seat. I did add the 10" Memphis behind the drivers seat it the empty hole. All driven by the Alpine PDX 1000.
It's ok. Doesn't back screws out of the boat or anything, but I like to think that on those early pre-dawn mornings... before the sun really comes over the horizon, but you can still see pretty well... when you can hear the frogs jumping, the occasional flip of a fish tail... that when you crank it up a bit the waves radiate away from the boat.
sorry for the double post. i'm sure you've all seen this, but i just went to make sure it was all working right in the garage and my wife quickly confirmed.anybody know where i can score the carpet?
Image Dynamics IDQv3-D2 at 4ohms, 600W RMS off of Wet Sounds Syn6
¡Viva 205V!
2003 X2 MCX
Originally posted by BriEOD View PostIs that a Pyle sub?Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
