Originally posted by jason smart
View Post
18+ Klipsch Stereo mods
(Previous- '08 X2 w/MCX)
www.chesnuttech.com
Cheers mate , your correct plugs are already on wire loom at back of boat so just need to now re feed them back to the front so remote can be mounted next to glove box, luckily dealer is going to return the cables as they have confirmed are not required and they supplied them incorrectly . Blue tooth device works great even from at least 25 meters from the boat!
Originally posted by jason smart View PostCheers mate , your correct plugs are already on wire loom at back of boat so just need to now re feed them back to the front so remote can be mounted next to glove box, luckily dealer is going to return the cables as they have confirmed are not required and they supplied them incorrectly . Blue tooth device works great even from at least 25 meters from the boat!
There is a can-bus hub under the observer seat and power and ground, it should just be a matter of connecting 2 can bus wires to the hub (High and Low are in a single Deutsch/amphenol 12 pin connector with built-in bus connections) and then finding switched 12v power and ground. On my XT22 the can bus hub under the passenger side has 3 openings.'18 XT22 w/5500 & Upgraded Premium Stereo
www.chesnuttech.com
Originally posted by eecyclone View PostCan't you just use wires that are already in the front passenger side instead of re-feeding the transom wires to the front?
This is the harness I’m talking about. I think the 2020 passenger remote option ties into this canbus connector under the observer seat.
www.chesnuttech.com
Originally posted by eecyclone View PostJust received the custom cables I designed in for connecting aftermarket amps to the Klipsch DSP- JL, Wetsounds, Kicker, etc. These will drop the voltage down to less than 4V if you’re using an amp that doesn’t have a high voltage input. There is one version for the tower, bow, cockpit, and helm zones. Type 2 is for the subwoofer zone. Send me a PM if interested.
Originally posted by NGC View PostDo your adapters have an advantage over the LOC my boat currently uses for the REVO 12 XXX?
The main advantages are that the DSP adapter is plug and play so no wires need to be cut. The adapter also includes the blue remote turn-on wire. Sonically there shouldn’t be any difference between the 2 options if the LOC is a quality unit and installed correctly.'18 XT22 w/5500 & Upgraded Premium Stereo
www.chesnuttech.com
Has anyone changed out the 10” free air sub behind driver seat with a regular sub and enclosed it? Any particular requirements? Or is it easier to just add an amp and throw a 12 in an enclosure in there?
Thanks
2018 XT23Last edited by Mikekee; 05-20-2020, 07:21 PM.2018 XT23
2019 Avalon 2585 Catalina Platinum Entertainer.
Originally posted by Mikekee View PostHas anyone changed out the 10” free air sub behind driver seat with a regular sub and enclosed it? Any particular requirements? Or is it easier to just add an amp and throw a 12 in an enclosure in there?
Thanks
2018 XT23'18 XT22 w/5500 & Upgraded Premium Stereo
www.chesnuttech.com
Klipsch Stereo Upgrade Help
Hi Everyone,
I own a 2019 XT21 with the Advanced Audio option which includes cockpit, bow, and S80 cans on the tower, plus the sub. Compared to my 2014 X10 with a Fusion/JL Audio system, I have been extremely disappointed with the sound quality and volume level on the new boat and I need to improve it.
I've read through this forum and really appreciate the knowledge all of you have shared shared here, but I'm not an audio expert, so I have a few questions I need help with:
- Is the root cause of the poor sound quality due to the Klipsh amp(s) and the Klipsch DSP?
- If I replace the amp(s) with JL Audio VX amp(s), will the sound be significantly better?
- Would I require anything besides the amp upgrade? Will the amp's built-in DSP cancel out the changes made by the Klipsh DSP (sorry, I don't really understand this)?
- Is there any functional/performance difference in between the JL VX and MV series amps besides the MV being designed for marine applications? Which series is the better choice?
- Considering the fact that I need 6 channels plus a sub, would it make sense to use an 8-channel amp and bridge two outputs for the sub, or is it better/necessary to have a separate amp for the sub? I plan to replace the free-air sub with a sealed sub.
- EECYCLONE, do you still have amp input cables available for sale? If so, please let me know how to buy a set.
- Is there anything else I'm missing that I should know?
Thanks for your help!
-Chuck
Originally posted by Mikekee View PostThank you! Is there a plug and play system yet to tie in? I figured by now, someone has developed one.
Yes, I made adapters so it’s all plug and play. Send me a PM if you're interested in purchasing one.Last edited by eecyclone; 05-30-2020, 05:34 PM.'18 XT22 w/5500 & Upgraded Premium Stereo
www.chesnuttech.com
Originally posted by Ragged Edge View Post[*]Is the root cause of the poor sound quality due to the Klipsh amp(s) and the Klipsch DSP?
Originally posted by Ragged Edge View Post[*]If I replace the amp(s) with JL Audio VX amp(s), will the sound be significantly better?
Originally posted by Ragged Edge View Post[*]Would I require anything besides the amp upgrade? Will the amp's built-in DSP cancel out the changes made by the Klipsh DSP (sorry, I don't really understand this)?
Originally posted by Ragged Edge View Post[*]Is there any functional/performance difference in between the JL VX and MV series amps besides the MV being designed for marine applications? Which series is the better choice?
Originally posted by Ragged Edge View Post[*]Considering the fact that I need 6 channels plus a sub, would it make sense to use an 8-channel amp and bridge two outputs for the sub, or is it better/necessary to have a separate amp for the sub? I plan to replace the free-air sub with a sealed sub.
Originally posted by Ragged Edge View Post[*]EECYCLONE, do you still have amp input cables available for sale? If so, please let me know how to buy a set.'18 XT22 w/5500 & Upgraded Premium Stereo
www.chesnuttech.com
I completely forgot about the drive modes. I am replacing the stock 5 channel amp with a wetsounds SD6 for cockpit. Hopefully that helps.Aric
LONE STAR MASTERBASH 2022
Register Here
2019 XT22 - Ear Bleeder
2022 Sea Hunt BX22 CC
For Sale:
2020 Crest 240 SLC Tri Toon
Originally posted by eecyclone View PostI don't think anyone complains about poor sound quality, most complaints are due to lack of volume. The amps are underpowered to deliver required volume levels in an open boat on the water.
Yes, provided they are configured for the proper power levels and tuned correctly.
The VXi amps can't exactly cancel out the Klispch DSP programming, but they can improve it to your taste. The issue is that each boat function (drive, ski, wake, surf, chill) has different DSP programming. You would then need a corresponding DSP program for each mode. In my boat, I tuned my JL Twk88 DSP for 'chill' as when I am stopped I can hear the tuning more closely, and then deal with the tune being slightly "off" when I'm in other modes. Maybe I'll change this in the future but it seems fine for now.
Yes, they actually use different DSP chips in them. The VXi's chip is capable of higher fidelity audio. The MVi's chip allows for more DSP controlled pre-outs. The MVi chip also allows greater signal delay as boats are larger than cars.
I think if you're unhappy with the existing 8 channel/800 watt amp, then you probably won't be happy with a JL 8 channel/800 watt amp. I'd suggest going with two amps, especially if you're adding an aftermarket subwoofer.
Yes, I do. Send me a PM with types (tower, sub, cockpit, etc.) and quantities and I'll help get you fixed up.
