Originally posted by Tahoeblue
View Post
18+ Klipsch Stereo mods
Originally posted by Taco47001 View PostI'm guessing the 1200.6 is for the interior speakers? Seems like a lot of money to only gain a few watts... Not sure there will be much audible difference in 25w per speaker additional.... that's assuming you're planning on a 4 ohm load. If 2 ohm, you're gaining nothing. What is it about the Klipsch amp you don't like?
Originally posted by cal2vin View Post
I have the Twk88 in my 21 x24. I ran the +12v and ground directly to the distro blocks I installed for my amps. I'd grab your +12v and ground at the amp terminals to eliminate any ground loop issues. Yes you can combine L/R signals on the outputs from the DSP. They are actually mono signals anyways. Only the dash zone is a stereo signal.
1 Photo
Originally posted by Tahoeblue View Post
I was mostly wondering if anyone had any memory issues with the TWK 88 installing the 12V constant after the battery isolator instead of having it wired before the isolator. Good feedback on the L/R signals actually being mono, I was just starting the RCA connections
Originally posted by Snipe243 View PostI’m adding 2 additional tower speakers to my premium sound system. At this time, the towers are running off the 8 channel amp. What would you recommend doing? Splitting the towers and running both pairs off a separate 4 channel amp or leaving my present pair on the 8 channel amp and powering the second pair on an additional amp?'18 XT22 w/5500 & Upgraded Premium Stereo
(Previous- '08 X2 w/MCX)
www.chesnuttech.com
- Likes 1
I was mostly wondering if anyone had any memory issues with the TWK 88 installing the 12V constant after the battery isolator instead of having it wired before the isolator. Good feedback on the L/R signals actually being mono, I was just starting the RCA connections'18 XT22 w/5500 & Upgraded Premium Stereo
www.chesnuttech.com
- Likes 1
I appreciate reviewing all the posts regarding Klipsch audio... I have a stock 2018+ Premium Audio setup for an XStar with the T85 tower speakers and two stock 11" Klipsch subs.
I realize most folks are forklifting existing equipment and repowering with new amps & @eecyclone's cables, but if one were to remain with Klipsch, do you know if its possible to improve the base and tower speaker power output (i.e. bridging, etc. to the 2 stock & T85's) using any of the following Klipsch equipment, keeping existing zone & touch screen functionality?- KMC1PA - 2 Channel (bridge / use multiple?)
- KMC4PA - 4 Channel (bridge and/or use multiple?)
- KMC8PA - 8 Channel (bridge?)
- 508814 Klipsch 5 channel AMP
-ChrisLast edited by jackpine; 01-20-2022, 01:05 PM.
Originally posted by jackpine View PostI appreciate reviewing all the posts regarding Klipsch audio... I have a stock 2018+ Premium Audio setup for an XStar with the T85 tower speakers and two stock 11" Klipsch subs.
-Chris
uplandbird Thanks, good to know. Is there any benefit to staying with Klipsch by bridging existing and adding Klipsch amps (i.e. warranty, resale value, etc.?)
I have come across a few of the following from someone else's re-power and wondering if they would be simple enough to add/bridge for improving an existing premium audio setup?- KMC1PA - 2 Channel (bridge / use multiple?)
-Chris
Originally posted by jackpine View Postuplandbird Thanks, good to know. Is there any benefit to staying with Klipsch by bridging existing and adding Klipsch amps (i.e. warranty, resale value, etc.?)
You could use an 8 channel amp to repower your T85 tower speakers with more power than the existing 4 channel amp. The 8 channel can be bridged with a few of my adapters to output 200 watts x 4. I would still go with an aftermarket amp though. You'd have to check with your dealer but I doubt that warranty would cover any modifications to the system. If you want more information or instructions, let me know.'18 XT22 w/5500 & Upgraded Premium Stereo
www.chesnuttech.com
www.chesnuttech.com
I noticed many of the new top MC models (X24, XStar, etc.) are being ordered with a total of 4 Klipsch subs (an additional pair in the main seating area) in addition to the ones behind the helm and bow. Any idea how they are powering them?
Is this just Klipsch likely compensating for lack of power to the existing subs? I'm wondering if they simply increased power to the "standard" premium sub setup if that would provide nearly the same desired increase in bass that most high-end buyers are expecting?
