I am a new Mastercraft owner (2006 XStar purchased late last summer) and first of wanted to say thank you to all that contribute to this forum. Its so helpful and amazing at the amount of time you guys put into answering questions and helping others out.
So for my first post here is my question/issue.
I believe the audio system that came with my boat is original. Clarion CMD4 HU, 2 JL Audio Amps ( E2150 m and an E 6450M). The 6450 runs the 4 speakers in boat and a sub behind the helm. The 2150 runs (or did) the 2 tower speakers. The 2150 is now not turning on but it did last summer and no wiring has changed.
I am far from knowledgeable in stereos and installs but this is what I have done so far to try and figure it out.....
The fuse at the battery is fine. I tried jumping the +12v to the remote wire as suggested in the manual with no luck. I checked the power at the amp with a multimeter and there was power but here is where I am confused.... when the key is off there was 12.4 v where power comes into the amp. When the key was on(acc position or turned on to run) it only displayed 4.48v? (the 6450 still had 12.4v) Each amp has power running to it independently directly from the battery with a fuse in between. The remote turn on wire runs from the HU to the E6450 then jumps to the 2150. According to the manual there is no internal fuse in the 2150.
So I guess I have 2 questions.
1. Should the power to the 2150 drop like that?
2. Is the 2150 blown? My unqualified guess is it is done and I need a new amp.
Thanks in advance for any opinions.
Jay
Jay
