Fusion MS-IP700i and iPhone 11
  • Fusion MS-IP700i and iPhone 11
    What? Turns out the Fusion MS-IP700i is NOT compatible with my new iPhone 11. According to customer support at Fusion they will NOT be offering firm-ware to make the iPhone 11 work.
    Is anyone else having this issue? Anyone find a work-around (other than lightening to RCA)?
    Thank you much
    Can you expand in the issue? I’m assuming you connect to your 700i via MS-BT200 using Bluetooth. Can you share the email Fusion sent you?
      I had a similar problem recently when my ipod rolled over and died, it was only used for the boat and fitted neatly inside the fusion ip600, simple solution was to fit the fusion bluetooth and use Amazon music from my phone I shouldve fitted it long ago
