Originally posted by brucemac
View Post
Fusion - round remote?
Originally posted by dpb185 View PostHow did you plan on mounting the main unit ?
I'm asking because I like the Apollo functionality but I have the single DIN opening in the glove box and I don't think they will fit there. You're helm configuration looks like mine, I was wondering if your radio mounting hole is the same as well.
Leave a comment:
Originally posted by brucemac View PostLooking at the RA670 and RA770 units, but I don't have a good spot for either of the two compatible remotes. The small battery operated wireless remotes could work I guess, but no display and I suspect you can't connect two at the same time (helm and transom).
I'm asking because I like the Apollo functionality but I have the single DIN opening in the glove box and I don't think it will fit there. Youre helm configuration looks like mine, I was wondering if your radio mounting hole is the same as well.Last edited by dpb185; 11-03-2021, 05:12 PM.
Leave a comment:
here's a couple pics, as you can see, I don't really have a lot to work with outside of a round ~2.5in remote...
Leave a comment:
Originally posted by peytonvp View PostI just put in all new mediamaster stuff and I have really liked it. I used an MM50 for the source unit(I only needed three zones, inboats, tower, and sub), MMR40 by the driver, and the the MMR20 on the transom. I was going back and forth between fusion but just wound up going with the JL stuff.
Question for you guys, have you completely eliminated the need for a WS420 with these more capable remotes and multi-zone DMR's? Having the 420 right below my dash has been an incredibly easy and fast way to make quick adjustments, especially when driving. Keeping the 420 seems redundant if you can squeeze in quick/easy zone control at the helm, but having to futz around with my phone or reaching over to the glove box would be a PITA.
Curious what others have done, or have experienced.
Leave a comment:
Guess I'll take another look at JL's Mediamaster line, but I've been reading mixed reviews.
Leave a comment:
Thanks guys. Appreciate the replies. Moose, I checked out your thread and while I realize the wired remotes are pretty compact, I still don't think I've got the real estate or ideal location for one at the helm. I could possibly squeeze it in somewhere down low on the throttle shroud, but that seems less than ideal. Maybe I'll just have to roll with the ARX remotes for the time being.
One other question regarding 670 vs. 770: Is there an audible sound quality difference with Airplay versus BT (assuming high bitrate streaming)? Trying to justify the difference in cost between the two units. WiFi & Airplay 2 would be great, but if it's not much of an improvement in real world settings out on the water, the 670 would probably serve me fine.
Lastly, anybody found nice trim rings or bezels for the ARX remotes, or are they all custom jobbies at this point?
Leave a comment:
Brucemac, sorry if you’ve already done this, but note the Fusion Apollo head unit and wired remote, though rectangular, are each very compact. So much so that I was tempted to put the head unit at the helm and a remote at observer and transom. I just got lazy and used the existing NMEA wiring in the boat for ease of installation.
Install thread for the Apollo 670 though note the 770 unit upgrades to a touchscreen: https://teamtalk.mastercraft.com/sho...=Fusion+apollo
Either way, the Fusion Apollo stuff is really sharp, has high res color screens, and seems to be way more reliable than the early generation models. Good luck.
And their round wireless remote is slick and easy to install though to your point does not include power switch.
Screenshots below of the install templates, not to scale but larger to show dimensions.
Head unit template
Remote template
Leave a comment:
I did not see a round remote on display in Fusion's booth last month at IBEX. Their reps where busy talking to other guests. I waited a few minutes and went on, did not circuit back.
Leave a comment:
Anybody know if there may be a round remote in Fusion's not to distant future, or any new products on the horizon?
They used to offer the MS-WR600C, which looked pretty cool, but it's long gone and it wouldn't have been compatible with the newer source units.
Looking to upgrade an older Clarion M475 with (2) wired remotes. Looked at the M508 and that's an option with the adapter cable, but interested in the WiFi and Airplay functionality of the Fusion.
/edit I stand corrected, looks like you CAN pair more than one of the wireless remotes, but I also learned there's no power (on/off) functionality.Last edited by brucemac; 11-02-2021, 07:56 PM.Tags: None
Leave a comment:
