2011 X-15 Ballast Empty-How it works
  • Rwcook
    replied
    I thought that but then I said to myself, can it be that straight forward....and I guess it is. Thanks for the quick response.
    Leave a comment:
  • robadele
    replied
    On single pump systems, the pump reverses flow to push the water back out through the same hose as used for intake.
    Leave a comment:
  • Rwcook
    started a topic 2011 X-15 Ballast Empty-How it works
    Hi All,
    Just a quick question on where my ballast tanks empty. Currently there is a line that goes from the bottom of the boat (inlet) to the pump then from the pump to the tanks. When it empties, does it just go the opposite way out the inlet? I can't wrap my head around how the system works....
    Thanks
